Old 02-07-2015, 02:27 AM   #1
72timemachine
Worried about blowing one of those rubber oil lines on my diesel.
I have read about folks losing their engines due to the rubber oil line hose that goes from the block to the radiator just like on my 1984 6.2 diesel.
I tow with this crew cab 3500 and the last thing I need is to loose the engine out in the middle of no man's land.
I confess that on my 1985 6.2 diesel Burb I notice that same line starting to weep oil so I took them off and capped the supply and return at the block.
I ran it for sometime with no problems.
I am sure cooler oil is better but don't diesel engine depend on heat for ignition purposes?
Are there any better aftermarket hoses out there?
Thanks for any help in advance.
72timemachine is offline   Reply With Quote
Old 02-07-2015, 07:23 AM   #2
D13
D13's Avatar
Re: Worried about blowing one of those rubber oil lines on my diesel.
Diesels run on heat, yes. Heat is the enemy of oi and therefore bearing life. If you to the cooler makes a noticeable difference. All of the lines are subject to breaking or leaking at the crimps and the aftermarket parts are no better.
Common solution is to cap them (bad), put in hose nipples and run a loop of rubber hose (not good, less leaks but no cooling), replace them with aftermarket or OEM (better), have a hydraulic shop build you a custom set of hoses to replace them (figure out your routing first) (good) or replace them with braided hose (probably the best).
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-07-2015, 10:06 AM   #3
Corts60
Just here to tinker
Corts60's Avatar
If you still have your original hoses, take them to your local hydraulic shop and have them replicated. That is what I would do.
Old 02-07-2015, 11:18 AM   #4
hatzie
Moderator
hatzie's Avatar
Those are a common leak point.
Dorman makes the lines for the T400 chassis 6.5L... I bought a set from Rockauto in 2007 to replace the hoses on my 2000 6.5L and they are still leak free.
The Dorman 1985 6.2L upper and lower cooler hoses are available from Rockauto for around $25 each with all the seals etc needed to install.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
