![]() Join Date: Feb 2012
Who sells the best replacment rockers and cab corners
Getting close to welding my 2 cabs together for my crew cab , need to fit the rockers first . Who has the best replacement parts ?
Re: Who sells the best replacment rockers and cab corners
I haven't used them myself, but from what I read Top Banana sells pretty good stuff. If you go up to the google browser box above and to the right and type in rockers and also click in the circle next to 67-72 chevytrucks.com you should find a lot of info from those who did this same swap.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
I've heard a little about GMC Paul's being good, but was wondering the same thing, who is best.
![]() Join Date: Dec 2013
I ordered mine from Manes Truck Parts (Odessa Mo.) and they fit very well. I don't recall brand name. Ordered bed sides and tailgate from GMC Pauls and are good as well.
Tri-plus fit great for me
I would go with GMCPauls simply because he sells a rocker patch panel with 4" extended floor attached. Gives you more to work with. Also made from 19 gauge steel which is thicker than most other patch panels on the market.
http://www.gmcpauls.com/Patch_Panels.htm Look for 67-72 Outer Rocker & Extended Outer Cab Floor Set Good luck.... Bren
My other vehicle is unmanned.... |
