Old 02-07-2015, 02:25 PM   #1
Junkpyl
1972 C30 dually drop spindle install HELP!!
Hi all, I've looked around but cannot seem to find a definitive answer.
I just started installing my drop spindles from Bell Tech this morning and all is going well until I noticed the brake caliper mount is very different. The spindles are listed as 75-91 and they dropped right onto my ball joints with no issue. haven't gotten to mounting the rotor yet and hope there are no surprises there as well.
These new spindles seem to need a separate mount cradle for the caliper that is not in my possession.
I bought them used but in like new condition.
Anyone know what I'm up against?
Junkpyl is offline   Reply With Quote
Old 02-07-2015, 02:32 PM   #2
kwmech
Re: 1972 C30 dually drop spindle install HELP!!
What part number did you get? Should have been 3500
Old 02-07-2015, 02:39 PM   #3
Junkpyl
They are. Trying to upload picture from my phone but won't cooperate.
Old 02-07-2015, 02:47 PM   #4
Junkpyl
Here are two pix. the caliper mounts are different.
Old 02-07-2015, 02:52 PM   #5
Junkpyl
Looking online, I find a different caliper that is JB8 style? requires a cradle type mount that bolts to the caliper. I'm assuming this is what I need for these drop spindles. Anyone know if that style will work with my rotor or do I need to upgrade that as well??
Old 02-07-2015, 05:06 PM   #6
65standard
65standard's Avatar
Chevy has two different caliper, one single piston, and one dual piston. They also have two different rotors. Looks like your new spindles are for the bigger brakes. Dual piston calipers with the thicker 1 1/4" rotors. You will most likely need new caliper and rotors that go with those spindles.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 02-07-2015, 05:11 PM   #7
65standard
65standard's Avatar
Oh, and the brakes hoses are different between the two calipers.
Old 02-07-2015, 06:24 PM   #8
Junkpyl
I'll explore that avenue as well, thank you.
The spindles are for 75-91 according to the part number on them. My original rotors and ball joints fit as they should. The caliper is the only difference.
Old 02-08-2015, 01:54 AM   #9
kwmech
Those are not 1 ton calipers, they are 3/4 ton. Even the 1 ton is has a single piston caliper. AND as stated, you will need different hoses.
Are you sure it is a real 1 ton truck? Or something somebody put a dually rear end under.
Old 02-08-2015, 01:22 PM   #10
Junkpyl
All original 1972 C30 dually with 12' flatbed.
Old 08-06-2015, 12:05 PM   #11
truckzilla
truckzilla's Avatar
Did you ever find the right caliper that fits those dropped spindles? I'm having the same problem and the guys at Belltech were of no help. One even told me that the Bel-3500 was not intended to be used in a dually application. Strange how so many places advertise these spindles for duallys but they used what is called a clip on caliper.
truckzilla is offline   Reply With Quote
Old 08-06-2015, 01:25 PM   #12
Junkpyl
Yes, its the JB8 code calipers. They are the clip style and the trouble I had was with some castings that I got from the local auto parts store had an issue. They had material added and then machined the surface and it was a poor job. I went to NAPA and bought a set and they went on but if you aren't familiar with them, they can be a little tricky. As far as the spindle not fitting, I had no problem. They bolted right on to my ball joints with no issue. My truck is a 72 but I have no idea if the control arms had ever been swapped out with later model ones, I do not believe they have been. I sourced later model dually rotors as mine were pretty worn and the new ones had a good 1/4" of meat on them and were off a truck with the JB8 brakes. got them turned and put new bearings in and they slid right on. I have not driven the truck but around the block because it still needs other work but it does stop real good from 25 mph now
I hope this helps. Shoot me a message if you have any other questions, I'd be happy to lend a hand.
Old 08-06-2015, 01:45 PM   #13
Junkpyl
Name:  brake caliper.jpg
Name:  Truck spindle.jpg
Old 08-06-2015, 06:51 PM   #14
SCOTI
SCOTI's Avatar
Originally Posted by Junkpyl View Post
Junkpyl...
Check the center bore of your wheels & compare it to the hub. Those look like 99-later wheels which have a larger bore vs 71-98 trucks. Might be an issue you haven't realized w/the limited drive time.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-06-2015, 08:15 PM   #15
Junkpyl
Good eye on that one. I have had them on it for a while and did notice a little wobble at certain speeds. I've figured out I need hub centric rings to take up the slack just haven't gotten them yet.
Old 08-06-2015, 08:32 PM   #16
SCOTI
SCOTI's Avatar
Yeppers..... Glad you're aware. I had some made for the early hubs to late model (03-13) Dodge wheels. It was a little over 2 bills for billet aluminum.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-23-2016, 05:37 PM   #17
bd94s10
Thanks for the info. I picked up a kit from The Suspension Source and agree the resources needs to be updated. I was about to tear into my 1-ton now and took a long look at the calipers and recall seeing this thread when researching. Looks like I'll be in the boat to spend more money to get the front lowered. I finished the back last weekend and need to throw the bed back on.
Jason
bd94s10 is offline   Reply With Quote
