Old 02-07-2015, 05:59 PM   #1
itstheDRE4M
Power Steering Drag Link w/ Manual box?
I just recently purchased a 72 P/S Box and I'm trying to make it work with what I have on my 67 Frame and whatever P/S the PO had on it.. Problem is that I don't know what I have. What it seems is a Manual Box with a P/S Drag Link /stabilizer.. I know that with the 72 Pitman arm I will not be able to use this drag link.
Maybe someone can point me in the right direction, but I can't find a P/S Drag link which would make everything easy.
The wheel had way too much play and here I am today trying to fix it.
itstheDRE4M is offline   Reply With Quote
Old 02-07-2015, 06:38 PM   #2
itstheDRE4M
Re: Power Steering Drag Link w/ Manual box?
After some more digging.. it seems I have a manual w/ power assist from a camaro/nova..
Old 02-07-2015, 06:58 PM   #3
john
member #16
john's Avatar
67's had the power assist like your pics. You will need a center link from a truck no newer than 1970 to work with your 67 parts. In 1971 the tie rods etc are a different size. I think the 72 ps box and pitman arm should work. Someone will correct me if wrong.
john is offline   Reply With Quote
Old 02-07-2015, 08:37 PM   #4
itstheDRE4M
I know my current pitman has both open ends and the 72 p/s pitman has only one open end for the box, the other connects to the center link by balljoint
