Old member
This shows why removing the gas tank does nothing for more leg room in a stock truck! The seat is as far back as I can get it and it seat right for me. I'm 5' 9". The tilt wheel helps but I have a normal size steering wheel also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: May 2014
Re: Tank removing ???
Yeah I don't understand how people think it'll allow the seat to go back further. They must not actually look at it.
Old member
I have wondered before why someone doesn't do that panel like a corvette. That would be awesome if done right.
Something like this would give you the added leg room and be cool as heck all in one! Well I think so anyway. I bet you could get another 3-6 inches out of it as far as leg room. By the time you push the seat bottom further back the top would still get about 3" I would think. It would take a good metal guy though to get it right but very do able and it would also lead into a console in the floor. ![]() ![]() ![]() ![]()
#4 | |
![]() Join Date: Oct 2008
I will be cutting out sections of the metal panel around bucket seats to give me some additional space. It's a compound curve so not easy... not sure if I will wind up taking the whole piece out or not... I did take the gas tank out as well as part of this project... however I knew that the real room would come from cutting out the panel under the window I'll be shaving some foam out of the bucket seat backs, hopefully that will also buy me another inch or so... And I've also modded my brake pedal and gas pedal assemblies to give me more legroom. I'm 6'5" and it's a little cramped in there Pics when I get there |
#5 | |
Old member
![]() Quote:
I was thinking just cut the metal panel to fit around the seat with some nice trim on the edge to keep from ripping it if it came in contact with it. The head rest may have to come off also which isn't a biggie. I think there is enough room between the seats that my sub box would have the 2 subs stacked in the middle. ![]()
#6 | |
Old member
Thanks,
Looking forward to seeing your progress! Well I've talked to 2 of my local club members on F/B and they are willing to help me with this. One will help build the shroud around the seats the other said he would build the sub box! I just may end up doing it. ![]()
Old member
I washed the truck today and drove it to work. I measured the panel behind the seat. It looks like about 3" max if that much. I don't know if it would be worth the time and money for no more to gain than that!
Shaving the seats is a great option. I had 3" taken out of the pad and the bottoms shaved. Happy with the leg room and not so "straight up" seating position.
#10 | |
Old member
![]() Quote:
I have thought about getting some channel and making some new mounts with a little bit of rack. Looking at my picture the seat is almost even with the top of the metal panel. so if you cut the bracket as low as possible it should fit but you want have any up down motion on the seat. Not much anyway if any. ![]()
Subbed. 6'4". Interested to see what y'all come up with.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
Keepin an eye out
Andy - What are you using for CAI (the red piece)? Is it actually pulling air from somewhere besides the engine compartment?
Im looking for ideas... Thanks
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#13 | |
Old member
![]() Quote:
The air filter is a true cold air from the front of the radiator support. Here is a link for you. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=593464
#14 |
Keepin an eye out
Thanks/
#15 |
Old member
No problem your welcome!
#16 |
Seats are factory Buddy Buckets. I pulled the tank as well. But like I said shaving seats is what have me more room.
#17 |
Its a Truck Thing......
Andy,
If you have the 17in wheel and change it down you will see a difference. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#18 | |
Old member
![]() Quote:
#19 |
Cool to see you got the engine cover painted finally!
#20 |
Old member
Yea and he is the one doing my console now for me as well.
