Old 02-07-2015, 09:11 PM   #1
Green Valley Lawn
Headers for s10 chassis 350 swap?
I need to order some headers what ones are the best? Any to stay away from?
Green Valley Lawn is offline   Reply With Quote
Old 02-07-2015, 09:46 PM   #2
Dustint
Re: Headers for s10 chassis 350 swap?
Probably the easiest to assure fitment with the steering linkage and components would be the s10 v8 swap headers, I have a pair on my 48, on an 85 s10 chassis with a 350. Only draw back of these that I know of is some issue with #5 plug wire needing to be replaced every so often due to heat exposure.
http://www.ebay.com/itm/Patriot-Clip...-/390973160440
Some here like what I have on mine, however I got mine off craigslist for $70. Just have to watch for them.
Dustint is offline   Reply With Quote
Old 02-08-2015, 07:56 PM   #3
Atommik
Atommik's Avatar
I used S10 V8 swap headers . Patriot brand. I think they were from JEGS or Summit. Relatively inexpensive and have held up well in 2 summers of driving. You will need to run the steering shaft thru the header pipes. It sounds involved but actually went pretty easy with a good quality U-joint for the shaft.
Atommik is offline   Reply With Quote
Old 02-09-2015, 06:22 PM   #4
Green Valley Lawn
Thanks guys just ordered up a set of patriot headers from summit.
Old 02-10-2015, 09:18 AM   #5
1948GMC
1948GMC's Avatar
Headman headers is a really good quality brand and makes specific s10 v8 swap headers ant they fit perfectly
1948GMC is offline   Reply With Quote
