Old 02-07-2015, 09:32 PM   #1
KrazyRay
KrazyRay's Avatar
1970 Cab for Patches
Here's a non AC cab that I'm selling patch panels from. The floor, rocker, kick panel areas are bad, but the rest looks to be in good shape. Patches start at $25 plus shipping. The entire dash cut at the windshield is $75 plus shipping. Let me know what you need!
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 02-07-2015, 09:34 PM   #2
KrazyRay
KrazyRay's Avatar
Re: 1970 Cab for Patches
pics
Old 02-07-2015, 11:03 PM   #3
sduckworth13
sduckworth13's Avatar
Can you cut me the passenger side cab corner please? Can you please cut it similar to how this pic is please. If there is anyway to get it apart without removing the spot welds where the rear floor is attached to the cab corner and leave just the area of metal that's attached to the cab corner intact I'd appreciate. If there is a way to remove it by drilling out the spot welds cleanly that would work to but not necessary.
Scott
sduckworth13 is offline   Reply With Quote
Old 02-07-2015, 11:25 PM   #4
KrazyRay
KrazyRay's Avatar
Yes. $25 plus shipping. I will cut and verify that it is good and solid.
Thanks,
Ray
Old 02-07-2015, 11:26 PM   #5
sduckworth13
Thanks Ray.
Scott
Old 02-08-2015, 01:33 PM   #6
67chevy4x4c
Can you cut drivers side windshield lip off I need from the door post over 24 inchs
67chevy4x4c is offline   Reply With Quote
Old 02-08-2015, 02:22 PM   #7
fast70swb
passenger Side roof panel? About 20 inches from drip rail from windsheid to rear window. How much you think shippng?
fast70swb is offline   Reply With Quote
Old 02-08-2015, 08:33 PM   #8
twistedchevy
I see their is a wiring harness in their still, how bad is it?
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank.
70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank
Dads: 67 c10 step side(project)
72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter)
Ours: 67 c30 tow truck
70 c10 long bed 383stroker w/digital gauges(work truck)
twistedchevy is offline   Reply With Quote
Old 02-08-2015, 09:01 PM   #9
KrazyRay
KrazyRay's Avatar
Yes. Can you draw the piece you need on one of my pictures?
Old 02-08-2015, 09:01 PM   #10
KrazyRay
KrazyRay's Avatar
Yes. Can you draw me the piece also?
Old 02-08-2015, 09:03 PM   #11
KrazyRay
KrazyRay's Avatar
I will check on harness.
Old 02-08-2015, 09:26 PM   #12
enduroride
enduroride's Avatar
I would like to get a 8" x 8" square cut out of the front drivers side roof and 6" down the front post.
So go over towards the center of the cab from the corner of the windshield 8", then 8" towards the rear of the cab from the upper front door frame corner . The down the windshield post about 6 or 7"
Thanks, Wade
2016 Silverado2005 GMC Sierra
2002 Chevy Slverado Extra Cab (youngest sons)
2009 GMC Denali (oldest sons)
2015 Lexus 250i (wifes)
1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY"
http://www.louisianaclassictruckclub.com
enduroride is offline   Reply With Quote
Old 02-08-2015, 09:30 PM   #13
Hunter67stepside
How much for the gas pedal if the stud holes are not cracked. To Nashville. 37027
Hunter67stepside is offline   Reply With Quote
Old 02-08-2015, 09:39 PM   #14
6t727t2
Active Member
Ray, I'm looking for this cowl piece in no rust condition, mine is rusted low on the inside of cab. Shipping would be to zip 08015 NJ Thanks
6t727t2 is offline   Reply With Quote
Old 02-08-2015, 10:02 PM   #15
fast70swb
Here is the section I need hope this helps. About about 16 inches from drip rail . In need of the upper door jam part also that the roof tack welds to where the drip rail also welds to.. thank you so much.. and shipping would be to zip 73010
Old 02-09-2015, 07:54 AM   #16
enduroride
enduroride's Avatar
This is the section I was refering to in post #12
Shipping to 70769
Thanks, Wade
Old 02-09-2015, 09:34 AM   #17
KrazyRay
KrazyRay's Avatar
Attachment 1361017
Shipping to 70769
Thanks, Wade
$25 plus shipping for that cut, but I need to see if 67chevy is taking that section.
Old 02-09-2015, 09:35 AM   #18
KrazyRay
KrazyRay's Avatar
$8 shipped for the gas pedal.
Old 02-09-2015, 09:42 AM   #19
KrazyRay
KrazyRay's Avatar
$50 plus shipping for this section. I won't know if it is rust free until after I cut it. I can't get exact shipping cost until I know the weight, but I will send out fedex ground when possible.
Old 02-09-2015, 09:51 AM   #20
KrazyRay
KrazyRay's Avatar
$50 plus shipping for this section. I will cut the a pillar at the top, then I will start at the b pillar and cut it fat behind the seam, I will then cut parallel 17" from the passenger drip rail. so you will get all of the drip rail and some windshield lip that you can pare down to your needs. I will ship fedex ground and have cost when cut.
Old 02-09-2015, 09:53 AM   #21
KrazyRay
KrazyRay's Avatar
A rare storm is coming through here so I will be making the cuts on Tuesday when it clears up.
Thanks for your patience!
Ray
Old 02-09-2015, 10:45 AM   #22
fast70swb
10-4 .. I will hold off a couple days because I will be leaving town for work. I will contact you and let you know when I will need it
. Thanks
Old 02-10-2015, 09:37 PM   #23
67chevy4x4c
this is what i need
Old 02-10-2015, 10:44 PM   #24
Hunter67stepside
I'll take the pedal. Just please confirm that it mounts to two floor mounted studs and that the stud wells are not cracked. If ok please send parent info in pm
Old 02-11-2015, 01:49 AM   #25
KrazyRay
KrazyRay's Avatar
I made some cuts today. The cab corner is bad. The windshield lip was sacrificed to save the uncut dash, but I might be able to get it from another cab. The gas pedal is cracked. I will see if I have a good one. The wiring has many splices. I will get the 8x8 section tomorrow.
Thanks,
Ray
