Old 02-07-2015, 09:35 PM   #1
rs74
rs74's Avatar
350c transmission behind a 6.2 diesel? Doable?
From what I see they didn't off this combo for the diesel. Only the 400 and 700r4. I have a 350 lockup transmission sitting in the garage but it doesn't look like a torque converter is offered for it. I thought if so maybe put it in the short bed instead of rebuilding the 700. Truck has 3.08 gears in it so if it is doable then about what kind of rpm's would I be looking at on the interstate.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-08-2015, 09:37 AM   #2
Rascal_one2001
Rascal_one2001's Avatar
Re: 350c transmission behind a 6.2 diesel? Doable?
It will bolt up and function. The 6.2 uses a lower stall converter than a normal gas v8 so it will just have to be a little higher rpm for cruising when the converter is locked with tcc.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 02-08-2015, 10:45 AM   #3
rs74
rs74's Avatar
Yeah I am trying to figure out the converter and governor issues. Will a 400 diesel torque converter and governor work in the 350?
Roy
1987 R10 shortie
Old 02-08-2015, 11:59 AM   #4
Corts60
Just here to tinker
Corts60's Avatar
T350 and T400 have the same 1:1 final gear ratio. RPM on highway will be the same
Old 02-08-2015, 12:08 PM   #5
rs74
rs74's Avatar
Do you know about the converter and governor swapping over or if the 700 converter and governor will swap?
Roy
1987 R10 shortie
