Old 02-07-2015, 10:45 PM   #1
Squareforceone
Squareforceone's Avatar
Would this rear end fit my truck
My truck is a 1984 half ton 2 wheel drive (c10)
https://ottumwa.craigslist.org/pts/4849911495.html
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 02-07-2015, 11:35 PM   #2
andrewmp6
Re: Would this rear end fit my truck
Will it probably but its 6 lug and your c10 is 5 lug.
andrewmp6 is offline   Reply With Quote
Old 02-07-2015, 11:38 PM   #3
greg64
greg64's Avatar
I can't tell from the pictures if it's a 10 bolt or 12 bolt (I'd need to see the cover straight on), but either one should fit your truck. However, because the rear end is from a 4x4, it's 6 lug, and your truck being 2wd is most likely 5 lug.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 02-08-2015, 02:26 AM   #4
iceship
it will bolt up... Just need to find out the spline count for the new axleshaft you'll have to get or have them and the hub machined to 5x5 bolt pattern..
iceship is offline   Reply With Quote
Old 02-08-2015, 07:42 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
You can change out the axles for 5 bolt axles, many salvage yards have them and can get you what you need. We put a 12 bolt rear end out of a blazer under my son's 86 1/2 ton and it fit just fine.
Frank
piecesparts is offline   Reply With Quote
