Help, Cleaned Cluster Now Truck Won't Start
So, I took out the cluster today and gave it a thorough cleaning and added a couple LED bulbs. Put everything back together, tested the lights, then attempted to start the truck...nothing. When I turn the key it's as if the starter isn't getting any juice. Everything else appears to be working fine. I took it apart 3 times and cant find a problem. Anyone have any ideas or suggestions? It's a gauge cluster, not dummy lights.
...and the LEDs look so much better in the dash too.
72 C10 lwb fleetside -stock 350/350 combo |
![]() Join Date: Sep 2007
Re: Help, Cleaned Cluster Now Truck Won't Start
You could start by following your wiring to the switch. Look for any damage and jiggle the harness and try to start. If it starts its either loose someting or other in the harness, bad connection to the switch or switch is going bad.
1967custom |
Ok, solved it. I'm a little embarrassed to say that attention to detail is key; it helps to have the transmission in Park when starting your truck. Hahaha
Whelp... now you know the neutral safety switch works
1967custom |
that's funny. some times it's just the simple things
You're not alone, thought my starter or ignition switch was toast but the truck was in reverse. D'oh!
71 K20 64 GMC mud truck |
![]() Join Date: Dec 2013
safety first , you are not the first to do this , wait till you have a memory lapse and check all things possible and then du, you never hooked the battery back up, but then some don't disconnect it and wonder were is the smoke coming from
Old member
Been there done that!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
