Sticker on driver side visor 1972 K20
On the driver side visor there is glue residue from what looks like a sticker of some kind, is this a factory thing or PO add on?
Re: Sticker on driver side visor 1972 K20
My 72 C10 had cold start procedure on it, I've since changed visors. Might have had additional info but I can't remember. I'm sure others will chime in.
thanks, are these available reproduction? Ive looked at a few sites and catalogs but no dice
Looked like this. Can't help you with the correct part number for your truck though. Nor a supplier.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#5 | |
http://www.autopartsdb.net/assets/im...mg/D/DC911.JPG ![]() ![]() ![]() |
#6 | |
http://www.ebay.com/itm/72-73-CAMARO...-/351290090598 oops out of stock. Last edited by mechanicalman; 02-08-2015 at 03:46 AM. Reason: oops |
Jim Carter may have what you are after. He used to have a picture and it was described 8 years ago as the same type material as the originals. He does have a part number, you will just have to check with him.
http://www.oldchevytrucks.com/cart/p...27&i=9712|||||
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
Did you ever find a place to get one of these RedRoad? No luck with the eBay link and the oldchevytrucks.com link didn't show a picture. Mine looks like the one mechanicalman posted with the same date and part number at the bottom.
I've got a nicer set of visors I'd like to swap out but want to keep the sticker.
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
No, busy spending money on other parts right now. I remember someone selling them here a week or two ago but cannot find the ad, Ill keep looking and post it here if I find it.
T |
Here is the thread but looks like it was deleted by admins
http://67-72chevytrucks.com/vboard/s...d.php?t=701220 KS Above visor engine start procedure decal - The 1947 - Present ... 67-72chevytrucks.com/vboard/showthread.php?t=701220 Mar 17, 2016 - 7 posts - 7 authors |
Well, I guess I'll have to photoshop a copy up and print some. I'll need to source the material because it's cloth like, almost a light felt type.
