Old 02-08-2015, 12:09 PM   #1
85/Silverado
85/Silverado's Avatar
Engine Swap
Do I need a 1 or 2 ton cherry picker to do a engine swap on my Silverado?
85/Silverado is offline   Reply With Quote
Old 02-08-2015, 12:14 PM   #2
Ziegelsteinfaust
Re: Engine Swap
I use a 1 ton as are most I see for sale.
Ziegelsteinfaust is offline   Reply With Quote
Old 02-08-2015, 12:14 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Engine Swap
a one ton should do just fine even a half ton I have a cheap one from harbor freight and I haven't run into anything I cant lift with it
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-08-2015, 12:56 PM   #4
85/Silverado
Re: Engine Swap
This is what I was going to order today so I have everything I need.
Old 02-08-2015, 01:05 PM   #5
enaberif
Re: Engine Swap
1 ton is fine but if its a crappy quality beware the bolts and keep an eye on the hydraulic ram.
enaberif is offline   Reply With Quote
Old 02-08-2015, 01:07 PM   #6
SkinnyG
SkinnyG's Avatar
Re: Engine Swap
A fully dressed small block is around 575lbs, so 1-ton should be dandy.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 02-08-2015, 04:44 PM   #7
Pano
Re: Engine Swap
In my research a lot of members like the 4 wheel engine stands over the 3 wheelers for safety. Some feel the 3 wheelers are more prone to tipping. I haven't bought one yet myself.
Pano is offline   Reply With Quote
Old 03-01-2015, 01:14 PM   #8
85/Silverado
Re: Engine Swap
The problem I have found with these cheap engine stands is that they can't be turned over because of to much weight. As you can see here.
Do you think if I put grease in to it the crank will turn so I can work on the oil pan bolts?
Old 03-01-2015, 01:55 PM   #9
Slammed84
Slammed84's Avatar
Re: Engine Swap
Any of the basic stands are bad about rotating when there is a alot on the motor. Bare block turns great, but when you slap heads on they get hard to turn. Grease will help I'm sure. The 1000 pound stands with the four legs are far superior to the three leg. I almost tipped a 3 leg one time, could've been bad.
I really want one of the nice expensive ones with the screw type/hand crank rotating system. They are pushin $200 dollars if not more.
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 03-01-2015, 02:06 PM   #10
greg64
greg64's Avatar
Re: Engine Swap
I've got a 4 wheel stand that I like, and it has the same rotating head design as yours. I wrote "grease me" on the pipe with a sharpie to remind myself to put grease in there before hanging an engine on it. The grease does help. I also have a 3 foot bar I use for turning the engine over. The 1 foot that came with the stand is a joke (maybe an aluminum 4 banger).
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-01-2015, 06:17 PM   #11
Bigstevex4
Bigstevex4's Avatar
Re: Engine Swap
Use the picker to turn the engine.
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
