02-08-2015, 02:57 PM | #1 |
Frame clean up...will this come back to bite me?
Hello,
So I'm pretty new to the forum and I can usually find what I'm looking for when using the search so I haven't had a need to ask any questions yet but I'm sure this will be the first of many. I'm in the process of cleaning my frame and I'm taking it down to metal and and will be using VHT chassis paint. So I just want to know if I'm being to anal when getting all the little bits around rivets and other tight spots when taking it down to the metal? If I don't get every nook and cranny will it bite me down the road with rust issues? first time posting pics so hopefully they show up. Let me know your thoughts. I don't mind doing the work to get it totally clean but if I don't have to then I can move along a little faster. Thanks for any input. John |
02-08-2015, 03:11 PM | #2 |
Re: Frame clean up...will this come back to bite me?
Unless its greasy, oily, or a loose rivit I wouldnt worry about it. Your not goin to get paint between the mount and the frame, so I ont think there will be an issue... in your lifetime anyway.
I didnt even clean my chassis other than pressure washing. But I used rustoleum and it sticks to rust better than clean steel. Doesnt VHT mean Very High Temp? I thought that was just for headers, and had to be heated to cure.??
I just gotta get out here and do it, why? Cause nobody will do it for me... |
02-08-2015, 03:37 PM | #3 |
I would have had the frame sand blasted, cost about $150
Shops here will sand blast and powder coat the frame around $500
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
02-08-2015, 03:56 PM | #4 | |
http://www.vhtpaint.com/products/rollbarchassis/ |
02-08-2015, 04:02 PM | #5 | |
it has kicked my rear-end for a month now. |
02-08-2015, 04:52 PM | #6 |
You should be able to clean up those late few spots with a wire wheel on a small 4 1/2" grinder.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
02-08-2015, 05:03 PM | #7 |
Yep, The 4 1/2" grinder has been my main tool with a 18 volt drill for some of the tighter spots. just wasn't sure if it was necessary to hit all of it or if it was overkill. I've been doing just that as far as getting the smaller spots so far but its been a tedious process.
1970 C10 4.5/6 drop from ECE Body off restomod that seems to be never ending. Mama Tried... |
