manual transmission
Driving my new 1972 GMC
I have a few old cars but I dont remember the GMC transmission being so finicky to get the into gear without double clutching- must be part of the pleasure Is there anything I can add mechanically to shift easier- especially first and second gear? thanks -Michael Last edited by michaely31; 02-08-2015 at 04:48 PM. Reason: transmission manual shifting |
![]() Join Date: Oct 2005
Re: manual transmission
You don't say what trans you have but a 4 speed has a real low 1 st. gear that is not syncro. The rest of the gears & all 3 foreward gears on the 3 speed are syncronized. If it is hard to shift to these gears your clutch may be dragging or the syncros are shot.
I shift all my manuals without the clutch. The SM465 (which is what your truck should have had originally) just likes to be shifted slow and not be forced. Once you get everything spinning the right speed, it will almost pull itself into gear.
Mine is a bear to get into second if I use the clutch. |
If its the sm465 then the shifter is probably pretty sloppy which makes things even harder. There are a couple easy fixes for the slop but they all kind of turn into a regular maintenance thing. Check this out http://www.pirate4x4.com/tech/billavista/sm465/
thanks guys- will share with my mechanic also
4 speed..... while 5 speed if R is for racing? |
Are you using 1st? For normal driving you shouldnt use 1st or low, its 6.55:1. The SM465 is really just a 3 speed with a granny low. Start in the back left gear, get the shifter closest to the drivers seat
#7 | |
All about them K’s
![]() Join Date: Jun 2014
Not trying to be a no it all but just saying how the shifters on the trucks I've driven read. Also the 465 shouldn't require double clutching.(I drive tractor trailers so my definition of double clutching may be different than yours) They are synchronized as said above except for L. I too don't normally use the clutch when driving the 465. If your having trouble I'd bet your syncros are gone.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
yes, not double clutching- sounds like syncros
and will be gentle with engaging as suggested thanks |
#9 | |
When people talk about both the 465 and 4500 it can get confusing depending on what they know about the tranny |
#10 | |
All about them K’s
its the syncro
Normally I also don't use the clutch when shifting my 465 and I only use 1st when I am pulling a trailer and even then it is just to get her moving without burning up the clutch. I don't even use it with a load in the back. As far as I am concerned, this gear box has never been known for quick shifting as the ratios are spread really far apart and were commonly used in medium duites with 2 speed axles. I have wanted to install a ranger overdrive just to have a gear between third and forth but it's just not worth the money involved. I just take my time with the shifts and they are very smooth even with no clutch.
With all that in mind, I didn't open mine for the the first time until 2 years ago at 452,000 miles and only needed bearings. For me, that places it in the bulletproof catagory.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
