02-08-2015, 09:05 PM | #1 |
Robert Olson Transport
What did you get done 2/8/15 edition
I got in the new carb for the plow truck because I cant get the old one to work anymore, changed the motor on the plow and think I finally got some stuff purchased for the project how about you all
02-08-2015, 11:56 PM | #2 |
Re: What did you get done 2/8/15 edition
Ordered some parts, and I think I'm getting a running 350 delivered to me for 500 bucks with an almost new edelbrock 1406. It's been too cold out to do anything!
02-09-2015, 12:25 AM | #3 |
Did a cam swap, put bigger jets in the carb, and got headers put on. What a night and day difference!!
02-09-2015, 03:12 AM | #4 |
Squarebody guy
Changed the fuel pump on my 88 TBI CCLB dually. Test drive had it running ok after it got hot(old pump would overheat and pressure would drop to less than 4psi).
02-09-2015, 09:07 AM | #5 |
Sanded bondo on the bed floor then DA'd the floor & inner bed sides in preparation for the Line-X shoot.
Also went out & pulled everything used for a vacuum brake system between the master cyl to the pedal pad. I got the pedal assembly all cleaned up & painted. Now I just have to get it installed, swap the leaking master cyl out, repair the paint damage on my vac booster can, & bleed the brakes again.
02-09-2015, 09:41 AM | #6 |
Replaced the vacuum modulator and line on my transmission and am being taught a lesson in humility by slowly realizing I am going to have to let a professional fix my transmission instead of doing it myself in the garage.
02-09-2015, 10:06 AM | #7 |
Got all the interior swapped into the diesel short bed. Steam clean the carpets in the C10 and K30 too.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
02-09-2015, 10:41 AM | #8 |
I know the pieces fit
Door pins and bushings on my CUCV. I regret having put that off so long, it was an easy job with an engine hoist holding the doors for me. Few minor adjustments and the doors close great now.
02-09-2015, 10:59 AM | #9 |
Chassis Saver on the back half.
02-09-2015, 11:06 AM | #10 |
chassis saver the front floor of my sub and removed the trans crossmember to add exhaust cutouts.
02-09-2015, 11:17 AM | #11 |
did the first test fit of the nv3500 in the suburban.
need to mark floor for cutting, install driveshft to meas. for length, and get a meas for the hydraulic line length so i can get that made. |
02-09-2015, 06:27 PM | #12 |
I prepped my hd hubcaps for use with the manual hubs on my '85 K20. Hopefully new tires coming soon...
