Old 02-08-2015, 09:35 PM   #1
GMtrucknut!!
GMtrucknut!!'s Avatar
Smile Neutral safety switch
I have installed an ididit steering column along with a locar cable operated column shift in my 55 second series and would like to have a neutral safety switch . I was wondering what setup most have used. I would like one that would use both park and neutral .
GMtrucknut!! is offline   Reply With Quote
Old 02-09-2015, 10:59 AM   #2
mr48chev
mr48chev's Avatar
Re: Neutral safety switch
I think Locar sells a kit for the neutral switch or you could go with the kit that uses a switch off a Ford that fastens to the trans pan bolts.
Locar kit https://www.danchuk.com/ItemForm.aspx?Item=15880
I'm not finding the kit that use the Ford C-4 style switch.
My ongoing truck projects:
Old 02-09-2015, 01:36 PM   #3
OrrieG
OrrieG's Avatar
shop the price, I did a quick search looking for another style I remembered(could not find it) but saw the lokar unit at speedway for $30.
OrrieG is offline   Reply With Quote
Old 02-09-2015, 02:52 PM   #4
octanejunkie
octanejunkie's Avatar
I'm using a GM column so I have a OE switch, but I looked at the lokar and Painless trans switches.
Painless manual PDF here
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time
'59 Chevy 3100 Stepside
octanejunkie is offline   Reply With Quote
Old 02-09-2015, 11:09 PM   #5
mr48chev
mr48chev's Avatar
As OrrieG said, shop the price as the link I posted most likely is on the high end or at least full list price. It was a quick link to grab this morning for show and tell.
Octainejunkie, If you are running a column shift there isn't much reason to change from the stock switch unless you like change for the sake of change and spending money. The stock switch also has the backup light switch in it so that is a point in it's favor.
Old 02-09-2015, 11:49 PM   #6
octanejunkie
I am not looking to move away from the OE column switch. I only posted here for the benefit of the OP.
The Painless kit I referenced also provides dual function neutral safety as well as reverse lights.
