Old 02-08-2015, 09:51 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
np205 outputs questions
I have a 71 and 84 np205s. Are the rear output splines the same between the two? For the front the 71 has a yoke the 84 has a flange, are they interchangeable? I have a 71 front driveshaft and an 86 front driveshaft that will need to be shortened to work with the flange. Thanks
Jim
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-09-2015, 06:50 PM   #2
obijuan
Re: np205 outputs questions
rear are all 32 spline.
front on the 71 is probably 10 spline. front on the 84 is 30 spline. entire front output shafts interchange if necessary.
obijuan is offline   Reply With Quote
Old 02-10-2015, 08:57 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thanks, I will need to pull the yoke off the 71 (1/2 ton) and put on the 84 (3/4 ton). I am using a 1/2 ton driveshaft and do not want to find a hybrid joint for the rear.
Jim
Old 02-10-2015, 10:24 PM   #4
franken
Are the front shaft spline counts the same? Maybe you can mix and match. Might lead to a balance problem, but the front isn't spinning at high speed if you have locking hubs.
Maybe a crazy idea...
franken is offline   Reply With Quote
Old 02-11-2015, 08:25 AM   #5
CUSTOM/10
CUSTOM/10's Avatar
As obijuan said, the spline counts are different so you would have to swap out the front out-put shaft in order to swap the yokes. I have done this to a few np205's but in reverse, I like the flange better than the yoke style.
And it's best to do the swap with the T/C's on a bench, I have done this in the truck but it's VERY difficult !!!!!
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is online now   Reply With Quote
Old 02-11-2015, 02:09 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The front is fine. I am having the front driveshaft shorten. The rear is what I need to swap, I have a 1/2 ton yoke and a 3/4 ton yoke, the driveshaft is 1/2 ton. I want to pull the big yoke off and put the 1/2 ton yoke on.
Old 02-11-2015, 02:31 PM   #7
CUSTOM/10
CUSTOM/10's Avatar
OK, I thought you were talking about the front. I believe the rear has the same spline count. If not you could swap out the whole out put assembly.
I did that with a later model np205 from a blazer, they came with a slip-joint.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 02-11-2015, 09:48 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
cool, going to swap yokes this weekend then.
Old 02-11-2015, 09:48 PM   #9
franken
Actually I was speaking of the front driveshaft splines, not the output of the TC.
Old 02-14-2015, 07:12 PM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
All swapped. Thanks
Old 02-16-2015, 11:32 AM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Well, looks like I'm going to put the 1350 yoke back on since I found the hybrid joint to use. Oh well, thanks for the input I was glad to see things were kept the same over 15 years.
