Old 08-24-2003, 05:34 PM   #1
Canada20
Drip rail rot
Hay all.
I was poking around my truck yesterday, daydreaming (about all I can afford to do with it right now )...anyway, I noticed some rust holes just above the windshield on the inside of the cab. The drip rails are uneven on the horizontal surfaces like they're bubblkling out so I think they're rusting from the inside out. Is this a common problem? Am I in for a pile of work to fix this and what kind of options are there.
Many thanks,
Greg
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 08-24-2003, 06:57 PM   #2
JadeEmperor
I'd vote for shaving them all together. I'm getting ready to bite it and take on the task myself but from what I've read and heard it's a delicate task
Jimmie
Modern Vintage Autoworks
- '70 Chevy C10
- '74 Chevy C30 3+3 Dually
- '04 Chevy Colorado
Built, NOT, Bought. If you build it...they will ENVY!
Drive Slow, Scrape Hard, or Take Your Truck and GO HOME!
JadeEmperor is offline   Reply With Quote
Old 08-24-2003, 07:26 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
You can buy a "header patch panel" for the inside of the cab above the windshield, but the rust in the driprails won't be that easy to fix. My driprails are compleley rotted out, with rush on top of and below the driprail, almsot all the way through in some places. If the rest of your cab is in good shape, you can "clip" the cab, and weld on a new section of cab from the windshield pilliars to the floor....if the rest is rotted, i would look for a new cab (what i am doing for mine)
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 08-24-2003, 08:13 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
My vote would be to shave them that's what I am gonna do.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-24-2003, 10:51 PM   #5
Canada20
yikes!! sounds like a nasty task. Good for learning, maybe, but nasty. I guess if it's far-gone, it's not like I could make it much worse.
I'd been wondering about shaving 'em anyway; does that cause any day to day problems like water dripping through open windows or anything? Rotting the windshield frame maybe?
Thanks for the replies!
Greg
