Old 02-09-2015, 02:29 AM   #1
JointTech
JointTech's Avatar
fuel line fittings and adapters
Im making a fuel line to go between pump and carb. Coming from the carb is a -6 AN female. On the end of the fuel line im making is 5/8 18 inverted thread.
I have an adapter from -6 AN to 3/8 thread but I cant find a coupler to go between.
I think I can find a -6AN to (whatever I need) but I see almost no female to male adapters.
I guess my question is what is the female part of the piece on the bottom?
Or If you had 3/8 line what would you use to get where Im getting.
Assume I can only make 45 flares so doing it all in AN wont work.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 02-09-2015, 03:20 AM   #2
Crazyduck
Re: fuel line fittings and adapters
Not sure if it helps but I used the fitting off my old quadra jet to work with th edlebrock... Also howdy kinda close neighbor
Crazyduck is offline   Reply With Quote
Old 02-09-2015, 03:45 AM   #3
JointTech
JointTech's Avatar
on the side coming from the pump is that a female fitting? Neither home depot or pep boys has a female fitting for a steel line... feel like im taking crazy pills.
hi neighbor
72 C20 Long Bed
Old 02-09-2015, 04:02 AM   #4
JointTech
JointTech's Avatar
nevermind. I think I found what I need. It must be made of gold for $17 though..
-6AN male - 5/8 18 Female
http://www.jegs.com/i/Russell/799/64...FcZbfgodbK4A5A
72 C20 Long Bed
