Old 02-09-2015, 10:12 AM   #1
Arl37
Which POSI wil fit my 69 C10 3 series Differential
I have a 69 C10 with the factory 3:07 Ring Gear and Pinion in it. I is my understanding because I have the factory 3:07 it means means I have a 3 series case.
I am going to upgrade to a 3:78. I have purchased a 3:78 R & P from Summit which will fit my 3 series case.
I have now decided I would like to add a POSI. In looking at Summit and Jeggs I seem to get conflicting info as to whether a POSI is available for the 3 series case.
Does anyone have any thoughts on a POSI that would fit 3 series case with the 3:78 gear?
Also, is any modification required to the diff to make the POSI fit?.
Arl37 is offline   Reply With Quote
Old 02-09-2015, 01:58 PM   #2
Mike C
Mike C's Avatar
Re: Which POSI wil fit my 69 C10 3 series Differential
The Posi IS the case...
Yes, the 3.07 have a 3 series case. The 3.73 (right?) are normally in a 4 series case, but you can buy a thick gear as it looks like you have done. Now you just need to buy a 3 series positraction to fit your gear.
I would by the Eaton or the Yukon DuraGrip. I prefer those over the Auburn unless you can still get a Pro with clutches.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-09-2015, 02:07 PM   #3
Fitz
Drive Train Specialists has the 'case' you need:
http://www.drivetrainspecialists.com...ed19587-1.html
This is an Eaton series 3 carrier for an 8.875 in truck 12 bolt diff.
Fitz is offline   Reply With Quote
Old 02-09-2015, 02:14 PM   #4
leftybass209
leftybass209's Avatar
Yukon duragrip isn't available for a 12 bolt truck application. All the research I've done suggests new Eaton or pull one from a junkyard and then have it rebuilt.
leftybass209 is offline   Reply With Quote
Old 02-09-2015, 07:25 PM   #5
Mike C
Mike C's Avatar
Huh. Funny, I'd looked all through their applications but never noticed that. I'm planning on one for the 9.5" in my Jimmy. And maybe my 11.5" instead of the Gov-Bomb.
Goes to show you even the aftermarket doesn't want to support the truck 12 bolt.
44 Willys MB
52 M38A1
64 Corvette Coupe
