1953 1 1/2 ton rear air suspension
Hello, I was wondering if any one knows of a prebuilt 4 link set up that's a weld in or bolt in? I'm wanting to be able to put air ride on the back, and it bee to be strong enought to handle being a car hauler/tow hauler. Any info would be great thanks
Re: 1953 1 1/2 ton rear air suspension
I got my 4 link from Custom Connection. It is 1.5 DOM .25 wall and all the tabs/brackets are .25 thick as well.
The bag positioning would be more important though. You would want bag over axle not bag on bar.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
What kind of truck did you put the system on?
Its not on yet. I have a C20 3/4 ton. I ended up switching plans and am switching to 1/2 ton but since I am going to go with a turbo LS I figured the heavy duty suspension couldn't hurt.
I have seen people run 4 2600 bags over axle on a dually set up.
Okay thanks for the info! They seam like a pretty easy system to set up
Or something like this http://www.scottshotrods.com/4-bar-4-link-suspension/
okay thanks I will check it out
