Old 02-09-2015, 02:07 PM   #1
par4tom
Hella H4 Configuration
I have a 1961 C10 with the four headlight configuration...I'm building my own headlight relay harness but need to know which connector is which on the back of the Hella H4...
If I'm holding the light in front of me so that the middle prong is on the top, and looking directly at the back of the headlamp, which connection is the lowbeam, which is the highbeam and which is the ground?
Sorry to ask this simple question but I seem to get a different answer from several different sources.
The bulb I'm using is a standard Hella H4 bulb...
Thank you,
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 02-09-2015, 03:52 PM   #2
Cooper197
Cooper197's Avatar
Re: Hella H4 Configuration
From the direction you're looking at the light, this image should be the correct wiring for an H4 system.
http://www.mypage.tsn.cc/roddqld/soc...ng_diagram.jpg
Cooper197 is offline   Reply With Quote
Old 02-09-2015, 11:19 PM   #3
par4tom
Thank you...
My Build Thread
