Old 02-09-2015, 07:36 PM   #1
11SECSS
11SECSS's Avatar
1971 swb c10
Im new to the site and the truck scene.My question is I just a 71 C10 that has 6 lug wheels and drum brakes front and rear .A buddy said it has to be a 70 does anyone know ?. Also whats the best way to get disc up front and lower the truck about 2-3 inches already has some wheels so trying to say 6 lug. Here's a pic of the truck.
11SECSS is offline   Reply With Quote
Old 02-09-2015, 07:44 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: 1971 swb c10
Not a 71 with drums.....
Check the VIN TAG, SPID and frame numbers, bet some of them don't match....or titled wrong....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 02-09-2015, 08:00 PM   #3
11SECSS
11SECSS's Avatar
Re: 1971 swb c10
Well the VIN tag matches the title as far as SPID its been painted over and not able to read it where at on the frame is the VIN will check that once weather is nice. So its possible someone put the cab on a earlier frame.
Old 02-09-2015, 08:31 PM   #4
jim ellis
jim ellis's Avatar
Re: 1971 swb c10
is it a 4 wheel drive? jim
jim ellis is offline   Reply With Quote
Old 02-09-2015, 08:55 PM   #5
71meangreenc10
Re: 1971 swb c10
It is possible, you wont know until you check the frame numbers. Are the rivets correct on the VIN TAG? More pics of the interior and under the hood would help. The big No No for me is the drums/6 lugs 2WD. I have never met anyone who loved drum brakes so much that they took off disks to install drums.
To answer your other question, you can get drop coils (if it has coils in the rear) to get what your looking for in the back, they also have drop coils for the front, they have kits to change it to spindles/disks for six lugs. Just remember when you start dropping the stance to keep an eye on the rest of the suspension for changes.
Smitty
71 C30 Wrecker
Old 02-09-2015, 10:12 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: 1971 swb c10
What is the 5th digit in the serial number. If its a 1 then the truck is a 71 if its a 0 the its a 70.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-09-2015, 10:19 PM   #7
leftybass209
leftybass209's Avatar
Re: 1971 swb c10
Frame vin needs to be matched to the body vin to avoid swap problems. Most DMVs will type the words coming from your lips for a title so anything on the title doesn't mean anything. This can be a suspension swap, cab swap, frame swap, or someone who told the DMV 1971 instead of 1970. Make sure to get your ducks in a row to avoid issues.
leftybass209 is offline   Reply With Quote
Old 02-09-2015, 11:12 PM   #8
11SECSS
11SECSS's Avatar
Re: 1971 swb c10
Title and vin plate on cab both say CE141B6xxxxx (anyone have pics of factory rivets on cab plate so I can compare ) . Once the weather is nice I'll look on frame to see what it says before buying the disc brake conversion kit.
Old 02-10-2015, 12:14 AM   #9
Already Gone
Re: 1971 swb c10
You have a 71 frame cab sitting on a 67 to 70 frame and that frame may have been cut to make the truck a short box.
Old 02-15-2015, 05:14 PM   #10
11SECSS
11SECSS's Avatar
Re: 1971 swb c10
Okay went out and found me a 71-72 SWB rolling chassis to put my body parts on since it was cheapier then doing a disc brake swap plus I can clean up the chassis before hand.Then when done I'll put my rolling chassis on CL and see if someone buys it to get my $$ back. Also scored me a grille to replace the one I have.
Old 02-15-2015, 10:36 PM   #11
HeavyD
HeavyD's Avatar
Re: 1971 swb c10
Where inside mirror attaches is the metal flat or is there a raised triangle shaped pad? 71s had the raised area.
Ps nice truck
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
