Old 02-09-2015, 09:36 PM   #1
Iceburgh
Iceburgh's Avatar
LS in a AD guys
Love to know what you used for Radiator hoses.
I cant find a lower that will fit except the ugly $$ flexible ones with the big green stripe
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 02-09-2015, 11:22 PM   #2
torchlight
torchlight's Avatar
Re: LS in a AD guys
What are you using for the thermostat housing? I think the stock housing on most/all LS variants ends up with the water neck pointed pretty much straight into the inner fender, which makes fitting a hose challenging. I haven't fit hoses yet, but I did pick up a swivel-neck thermostat housing from Street & Performance. This allows me to point the water neck straight down directly at the radiator outlet, which should make hose fitment a lot easier. Here's a pic showing the housing installed:
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 02-10-2015, 05:12 AM   #3
dante81_98
Re: LS in a AD guys
I used a swivel neck as well. Mine was the Mr. Gasket one. This allowed us to point it down and it was pretty much a simple 90 degree bent hose that ended up working out I think. Nothing crazy.
dante81_98 is offline   Reply With Quote
Old 02-10-2015, 01:47 PM   #4
Daze57
Daze57's Avatar
Re: LS in a AD guys
torchlight
v nice pict sir ........clean setup
Daze57 is offline   Reply With Quote
Old 02-10-2015, 06:10 PM   #5
Iceburgh
Iceburgh's Avatar
Re: LS in a AD guys
Problem I have is the AC unit I am using. The swivel will not work due to the thickness and straight out would hit the belt.
1953 suburban build
Old 02-10-2015, 06:11 PM   #6
Iceburgh
Iceburgh's Avatar
Re: LS in a AD guys
sorry for the big pic.....on my phone
1953 suburban build
Old 02-10-2015, 09:44 PM   #7
eagleuh1
eagleuh1's Avatar
Re: LS in a AD guys
Nice looking setup Iceburg. Hope that constant ticking of the header on the passenger side frame doesn't drive you nuts. Sure looks close.
eagleuh1 is offline   Reply With Quote
Old 02-10-2015, 10:21 PM   #8
Iceburgh
Iceburgh's Avatar
Re: LS in a AD guys
Not as close as it looks.... it will be fine.
Kicked it over one hole on the mounts after the pic.....about 1/2" now
1953 suburban build
Old 02-10-2015, 10:26 PM   #9
Iceburgh
Iceburgh's Avatar
Re: LS in a AD guys
Hey Eagleuh1....do you know John Schaublin from Russelville?
1953 suburban build
Old 02-10-2015, 11:42 PM   #10
yossarian19
Re: LS in a AD guys
I would look at having 1 1/2" exhaust pipe bent and use a straight piece of hose to connect the water neck & pipe. Note that you MUST have a bead pressed or welded onto the pipe to keep it from leaking.
You can also find a lot of hose connectors (splices) and silicon / rubber bends in Speedway Motor's catalog.
I also used a selection of splices & OEM hoses I found on Summitracing.com : Summit has a huge selection of cheap OEM hoses that you can sort by diameter, length, curves, etc and between the two suppliers even a knuckle dragger like me can plumb a radiator.
EDIT: I thought about it a bit more and one supplier I used actually has a *TON* of parts that might help you here. I had great experience with them. Click here for a link. Siliconeintakes.com
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 02-11-2015, 12:40 AM   #11
dante81_98
Re: LS in a AD guys
Here is the one I used. From the picture you posted it looks like it should work. I don't have any picture handy though.
http://shop.mr-gasket.com/cooling-sy...swivel-30.html
Old 02-11-2015, 02:06 AM   #12
Groyd
Groyd's Avatar
Re: LS in a AD guys
I also used an s&p pointed straight down, not out. It works well. I've only driven a few blocks at a time so far though.
1951 Chevy 3100/S-10:
http://67-72chevytrucks.com/vboard/s...d.php?t=406072
1957 Chevy 3200
1971 2WD Blazer - Sold
Groyd is offline   Reply With Quote
Old 02-11-2015, 10:44 AM   #13
Iceburgh
Iceburgh's Avatar
Re: LS in a AD guys
Thanks for the links
1953 suburban build
Old 02-12-2015, 11:40 PM   #14
BlueJeep
BlueJeep's Avatar
Re: LS in a AD guys
Here's mine. Napa part # 8661 after some trimming.
Another angle:
Here's what was trimmed from the top and bottom to fit perfect:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-13-2015, 01:48 AM   #15
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: LS in a AD guys
Another angle:
What di dyou use on your upper?
dwcsr is offline   Reply With Quote
Old 02-13-2015, 08:31 AM   #16
BlueJeep
BlueJeep's Avatar
Re: LS in a AD guys
Napa #9053. Radiator is a 19x24" dual pass.
This was the candidate pool I brought home before I found the ones that worked. Took my bent up TIG wires to the store and matched it up with hoses of the correct size.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-13-2015, 09:07 AM   #17
Advanced Design
Advanced Design's Avatar
Re: LS in a AD guys
Thank you Blue Jeep!
Advanced Design is offline   Reply With Quote
Old 02-13-2015, 12:00 PM   #18
solidaxel
solidaxel's Avatar
Re: LS in a AD guys
Were you able to use the LS type thermostat with the swivel neck?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-13-2015, 08:36 PM   #19
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: LS in a AD guys
Thanks for the hose numbers, Looks like they will fit with a little tweaking. I'm using a Walker radiator made for an LS and they look to be almost a perfect fit. You saved me hours, much apreciated
Old 02-14-2015, 04:58 PM   #20
BlueJeep
BlueJeep's Avatar
Re: LS in a AD guys
I'm happy to help!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-14-2015, 07:33 PM   #21
eagleuh1
eagleuh1's Avatar
Re: LS in a AD guys
Iceburgh, no, name doesn't sound familiar. Any more clues.what does he do for living? Jim
Old 02-14-2015, 07:38 PM   #22
Iceburgh
Iceburgh's Avatar
Re: LS in a AD guys
He drove a show truck for Meguiars for a long time then one for Suzuki.
Blue jeep thanks the numbers worked out great. I am all set up.
Thanks again
1953 suburban build
Old 02-18-2015, 07:05 AM   #23
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Re: LS in a AD guys
Sub here for future ref on hoses. Thanks for posting this helpful info
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 03-03-2015, 09:58 PM   #24
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: LS in a AD guys
I wanted to add that I couldn't use the other lower hoses above without a new water neck. The NAPA 708 hose which is listed as an upper and lower fit with the stock neck and just trimming the hose a bit. it fits more GM cars and truck than I can list mostly 6 cylinder and early V8
