Old 02-09-2015, 09:46 PM   #1
Youey
Led taillights.
Well my stepside drivers side tail light decided to fail so went and replaced both with led tail lights and put them in the rear fenders. I did not change the flasher, all turn signals work brakes work, only problem I'm having is when running lights on brake lights do not activate. Not sure what controls the transition between the 2 but something isn't right. Any ideas?
Youey is offline   Reply With Quote
Old 02-09-2015, 11:48 PM   #2
leftybass209
leftybass209's Avatar
Re: Led taillights.
The reason your LED'S work is because you didn't change your front turn signals. If you change those to LED, you will need a new flasher. I have read and seen a lot of issues with the LED bulbs not working correctly with driving lights, and when they do work with driving lights there isn't really an intensity difference when the brakes are applied. The versions that I see that do work are: 50 leds total, 25 for driving lights +25 when brakes are applied.
leftybass209 is offline   Reply With Quote
Old 02-10-2015, 05:11 AM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Led taillights.
Grounds! Take some jumpers and make sure the fenders are grounded good to the truck it self.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-10-2015, 07:50 AM   #4
Youey
Re: Led taillights.
Grounds are covered. Have each light grounded to frame.
So should I try the flasher see if it clears it up? I mean I not sure how that would but just trying to figure it out.
Old 02-12-2015, 09:43 AM   #5
Youey
Re: Led taillights.
So I doubled up the grounds frame to light, body to light- got the drivers side to act normal, running lights brake works. Passenger side still not working right. Blinkers started not working while running lights on, ordered a new turn signal switch, from what I read through posts a lot of everyone's problems come from there guess we will see.
Old 02-12-2015, 08:51 PM   #6
kamikazekyle05
kamikazekyle05's Avatar
Re: Led taillights.
I would change to a no load flasher
kamikazekyle05 is offline   Reply With Quote
Old 02-12-2015, 10:37 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Led taillights.
You can try the no load flasher but if you have them mixed with regular bulbs it shouldn't matter.
Old 02-12-2015, 10:52 PM   #8
Youey
Re: Led taillights.
I'm gonna order one of those too. See if it helps.
