Old 02-10-2015, 03:35 AM   #1
Andy4639
Old member
Andy4639's Avatar
Question Fuel pressure gauge extenstion
Hey guys anybody know of a gauge extenstion for my feul gauge on the motor. Now that I have the cover over the motor I can't see the gauge was wondering what you all have done for this?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-10-2015, 09:59 AM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Fuel pressure gauge extenstion
Take the cover off if you need to see the fuel pressure?
It's not something that is needed unless you have to troubleshoot.
Anyway, it should just be a -4 AN fitting on the rail, pull your gauge, get a hose that's the correct length, and move it where you want it.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-10-2015, 02:44 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Plug for how I did mine.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-11-2015, 11:27 PM   #4
Jon01
Jon01's Avatar
Why do you care?
These motors have a very narrow window for acceptable fuel pressure - it'll let you know if there is a problem well before you have a bigger problem.
I don't monitor it on mine beyond keeping a loose eye on the wideband.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 02-12-2015, 12:02 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Fuel pressure gauge extenstion
The only reason I like it it lets me know when the check valve is going out on the pump. If the gauge is low then the check valve is not working at the pump which in turn makes it take longer to crank. And just because I have it on the motor I may as well beable to see it!
