49 steering column removal help please
After removing the steering wheel and inside brackets, what next?
I see 4 bolts on the steering box just at the bottom of the column, is that what needs to be unbolted? Thanks |
Re: 49 steering column removal help please
The column and gear box remove as a unit..from underneath
GOD BLESS AMERICA! |
I thought I answered this, pitman arm needs to come off, make location for reinstall, then box is unbolted from the frame and box with column is pulled out of the firewall. This assumes everything inside (steering wheel, shift mech, turn signal, mount to dash, etc.) has been removed or unbolted. If you are saving the stock shaft or relocating to install v8 search to find threads on that.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
