Old 02-10-2015, 04:46 PM   #1
troutin55
troutin55's Avatar
Driver Side Mirror Install
I have a 66 SWB, and I'm sure this topic has been addressed a million times before, but for some reason I can't really find the answer I'm looking for. Currently I don't have a driver side mirror, so I just bought one from LMC. Came with the arm, gasket, and screws. http://www.lmctruck.com/features/cbe/CBEMIQ.htm
Not sure I understand, but am I not supposed to use a washer and nut for the screws? Am I supposed to just drill a small pilot hole and screw them in without a nut inside the door? Have any of you guys done it this way with success?
thanks as always for the help. Clint
troutin55 is offline   Reply With Quote
Old 02-10-2015, 04:55 PM   #2
OldGMJon
OldGMJon's Avatar
Wink Re: Driver Side Mirror Install
there is a thread "mirror install help" that has this:
Projects:
65' Chevy C10 swb (rebuilt chassis)
65' Chevy Panel swb
64' Chevy C30 flatbed "above" 80' C30 "beneath")
Parts:
66' GMC 2503 & 65' GMC I1500
OldGMJon is offline   Reply With Quote
Old 02-10-2015, 05:21 PM   #3
forestb
forestb's Avatar
There should be nuts welded to the inside of door. The trick is finding them and drilling the holes in the right spot. Someone wrote a previous thread on this. Maybe he will chime in. I know it involved skinny arms and a lot of patience.
forestb is offline   Reply With Quote
Old 02-10-2015, 05:45 PM   #4
LVPhotos
LVPhotos's Avatar
Go inside door, there should be posts. Use a spring type punch, push and it pops. Or the like. Drill small holes, then step up size for screw head.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-10-2015, 05:51 PM   #5
63burban
Chevy addict
Drivers side holes are probably filled with Bondo but there are 5/16 nuts in the door .
Use you best imagination to find them. Actually make a template off another truck door or someone can maybe provide a template. Drill the Bondo out with a small dill and just run a 5/16 tap through the threads.
63burban is offline   Reply With Quote
Old 02-10-2015, 05:54 PM   #6
Paul Y
Just done this very job but on the passenger side.
As LV mentioned, you will need a punch and some plasters. The plasters will become apparent once you start....
Have a look at my build thread for a little more info.
P.
Paul Y is offline   Reply With Quote
Old 02-10-2015, 06:09 PM   #7
OldGMJon
OldGMJon's Avatar
Lightbulb Re: Driver Side Mirror Install
take the door panel off and shine a flashlight up into that area where the mirror should be mounted and you will see the nuts welded on up there. If you have a right angle drill you may be able to drill a small pilot hole from the backside through the welded on nut...if not, the template from post 2 can be your guide for drilling, just reverse it and use small drill first to gauge location.
Projects:
65' Chevy Panel swb
Parts:
Old 02-10-2015, 06:14 PM   #8
PGSigns
PGSigns's Avatar
I found them on my 66 by pulling the door panel and looking inside. They had bondo worms hanging out them. I plucked out the worms and used a 90 degree head on my dremel to drill a small hole from inside and finish up from outside. On my 65 they had screws in the holes and ground them off flush and filled with bondo. I could see the screws from inside the door. I used a template I found on line to locate the screws and slowly dug out the heads. They were the factory screws and came out with out a lot of trouble.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-10-2015, 07:20 PM   #9
OldGMJon
OldGMJon's Avatar
Jimmy
I thought that would work...
Projects:
65' Chevy Panel swb
Parts:
Old 02-12-2015, 03:08 PM   #10
troutin55
troutin55's Avatar
thank you all very much, much appreciated.
