Tilted Brake Booster?
Okay. So can anyone tell me why the brake booster on the 67 to 72 Chevy C10s were tilted? I'm looking to replace the tilted bracket with one that would make the master cylinder set level. However, I don't want to do it if there is a good reason not too.
![]() Join Date: Jan 2010
Re: Tilted Brake Booster?
I'm not sure the specific reason but I'm sure if they came that way from the factory then it needs to be that way. Interested to see what the actual reason may be myself.
![]() Join Date: May 2014
If you want to do something with it make the booster sit flush against the firewall like others have done. I agree it looks pretty strange how far out and unlevel the whole thing sits. I had a friend who thought I did something wrong after I installed my power brake setup. I was like trust me, it's right.
![]() Join Date: Dec 2012
Maybe it's so when you are on the brakes hard and the front dips, the fluid stays level?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
I can't be sure but I've read from several different sources that it's to help correct the push rod ratio on vehicles that came with both manual or optional power brakes.
horsepower junkie
i ditched my stock stuff and used a strait bracket and tucked the booster up closer to the firewall.looks ALOT better IMO...
67 ![]() 71 olds cutlass "S" mom bought new..12.30s@113MPH |
I think it had something to do with shift linkage clearance, too.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Thanks Everyone! Good input. I had heard it had something to do with the push rod as well as clearing the shift linkage.
Hey Leadfoot067: What bracket did you order? Did you have to modify the linkage to the brake pedal at all?
horsepower junkie
http://www.ebay.com/itm/RPC-Racing-P...57fa79&vxp=mtr
it was not a bolt in.i moved the upper studs down a little,and used a 8" dual power booster and that cleared the column shift linkage.and built an adjustable pedal rod to hook it up...if your not into welding holes and changing things the captainfab bracket will do the same thing..only it will bolt on...
![]() Join Date: Oct 2009
captainfab on this board makes very nice booster brackets
Thanks LeadFoot067 for the link. One quick question for you. You said you moved the upper studs down a little, which studs are you referring to?
#13 |
horsepower junkie
the 4 studs that stick out of the firewall to mount the booster bracket...
