02-10-2015, 10:27 PM | #1 |
Power brake booster 3 3/4" mounting
I have a 1964 c 10 with a power brake set up with an 11" booster I need to replace the booster. Trouble is all I can find have 3 1/2" center to center spacing to bolt to the firewall bracket. My booster has 3 3/4" center to center bolts. Is this a real old booster?
Is there any place I can find a booster that has 3 3/4" spacing? Thanks |
02-11-2015, 01:28 AM | #2 |
60-66 Nut
Re: Power brake booster 3 3/4" mounting
Is that an original brake booster? Yes a 3-3/4" center to center is a bit of an oddball. Are the mounting brackets such that the holes could be elongated to accommodate a 3-1/2" x 3-1/2" booster? My booster brackets are designed to use the very common 3-3/8" x 3-1/2" booster mounting studs.
02-11-2015, 01:37 PM | #3 |
any numbers on it? brand? post up a pic. Call the tech line at master power brakes, I bet they will know.
1961 chevy K10 my build is------------61K10 build |
02-11-2015, 02:59 PM | #4 | |
02-11-2015, 09:30 PM | #5 |
02-11-2015, 11:28 PM | #6 | |
02-12-2015, 01:33 AM | #7 |
60-66 Nut
That is a '67-'72 booster and mounting bracket. The '67-'70 boosters have a 3-3/8" x 3-1/2" center to center mounting stud pattern. The '71-'72's have a 3-1/2 " x 3-1/2" pattern.
02-19-2015, 11:04 AM | #8 |
I checked it again and the mounting studs are center to center the top ones are 3 1/2 "inch, the side ones are 3 3/8 inch. The firewall mount is 5 inches long.
02-20-2015, 12:56 AM | #9 |
60-66 Nut
Then you have a '67-'70 booster. There are also many other boosters that will interchange with that if you need.
02-20-2015, 01:17 AM | #10 |
DaveC1064, isn't it nice to have access to such knowledge--knowledge that can be counted on? Question asked; question answered; problem solved.
I see you've posted only 5 times since 2008. To me, that represents at most 5 answers you've asked for. I'd say that is a great record, as we continue enjoying our work on these old masterpieces. Gotta love this place--and thx again, Cap'n!!! Sam Last edited by luvbowties; 02-20-2015 at 01:18 AM. Reason: correct name |
