Old 02-10-2015, 10:59 PM   #1
FamilyBowTie
49 windshield trim help
Trying to remove the windshield, it looks to be original and the rubber is hard as a rock.
I've removed the inner/outer center pieces and was trying to remove the chrome trim. I can't seem to get the chrome off without damaging it.
Is there a good way to remove this piece so it can be saved?
Thanks again for all the help.
49 5 window on s10
http://67-72chevytrucks.com/vboard/s...d.php?t=671706
FamilyBowTie is offline   Reply With Quote
Old 02-10-2015, 11:03 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 49 windshield trim help
You'll have to take a utility knife and cut around the glass down in the seam where the glass sits. Its only about 1/4" in that area and once cut the windows will come out making it easier to get the trim out. Don't force the trim it will get out of shape and you won't be able to get it back in.
dwcsr is offline   Reply With Quote
Old 02-10-2015, 11:10 PM   #3
FamilyBowTie
Thanks will work on it some more, the rubber is rock hard.
49 5 window on s10
Old 02-10-2015, 11:54 PM   #4
mr48chev
mr48chev's Avatar
Follow Dave's advice and cut away the rubber. I'd cut it on the inside and trim it away so you can lift the windshields out and then take the glass and rubber off the truck and finish cutting the rubber apart to get the trim and glass out.
My ongoing truck projects:
