02-11-2015, 01:30 AM | #1 |
Can a late model stepside bed be used on a 64?
I'm thinking of picking up a 64 swb that has the original stepside bed on it now. It is in rough shape so the seller is including a newer bed circa 75-79 (I'm guessing). I would like to use the newer bed but install the original fenders & steps on it to keep the correct look. I'm guessing they are the same dimensions but obviously the holes would be in the wrong places.
Does anyone know if I can use the newer bed with the original fenders & steps? Any info is appreciated. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
02-11-2015, 12:51 PM | #2 |
Re: Can a late model stepside bed be used on a 64?
I know its been done before. Seen it. You know you could get reproduction long bed panels I believe, might be a little easier than trying to drill holes over hols already there.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-12-2015, 12:05 AM | #3 | |
Sam |
02-19-2015, 10:04 PM | #4 |
Scott,Mine had a 73-87 bed on it when i got it,the later bed is the same outside dimensions,but You will have about a 2 1/4 inch gap between step and bedside.The later bed also has a small lip in front of the wheel that will not let the fender sit flush with the side of the bed.I drove mine that way for about a year and a half,you can grind that lip off right where the fender goes if You want so it wont squeak.I bought a correct bed and put on mine.Hope this helps.
02-20-2015, 02:48 PM | #5 |
Thanks appreciate everyones help. Doesn't look like I will be buying the truck after all. Went to see it & asked him his best price. Called seller the next day to tell him I would meet his price, but now he is waiting for other interested parties to see it, that was over a week ago. Not sure why someone would put a price on something then not accept it. I don't work that way, but guess others do.
02-21-2015, 12:31 PM | #6 |
anything is possible with time, welders and cutoff wheels
