What Electric Fuel Pump Are You Running?
If my truck sits for more than a few days, my Edlebrock carb is empty and it takes several seconds of pumping the gas pedal while cranking the engine over before it will start. I'm thinking an electric fuel pump will pressurize the fuel in the line, sending it to the carb much quicker.
My question is, is this a common issue with the Edlebrock carbs? And will an electric fuel pump help? If so, please tell me what you are using. |
Old member
I would bet the diafram in the pump has gone bad letting the fuel to leak back.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: What Electric Fuel Pump Are You Running?
Thanks Andy, but it is a new pump. I heard the Edelbrock carbs are notorious for vaporizing the fuel due to heat soak.
Old member
Ok,
well get a electric one with no more than 20PSI and I would bet you need a regulator along with a return line to the tank. Not sure though never ran electric on a carb motor! ![]()
Holley red electric fuel pump. Puts out 7 psi so you do t need a regulator. Has its own internal bypass too. I like mine.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
carter p4070 will get the job one, i have sold plenty of them and to date no complaints or returns.
GMC K1500 1971 350 cu in th350 4wd Bondo Bob c 10 1971 stepside th 350 c10 1970 350 cu in manual air con stepside. |
#7 | |
Old member
![]() Quote:
