Old 02-12-2015, 12:46 PM   #1
The Swed
The Swed's Avatar
Bench seat question, rods sticking through the vinyl.
I want use a horse blanket cover the bench seat to prevent any further degradation of the exist foam. I noticed that the back of the frame has a support area with metal rods stick through the remaining vinyl. This must have had some kind of coverage when it was new. For the time being I was going to grind smooth the rods to take off the sharp edges. Is this the correct approach?
Thanks!
1970 C20 350/TH350, LB
God Bless our Troops
The Swed is offline   Reply With Quote
Old 02-12-2015, 01:37 PM   #2
flashed
Re: Bench seat question, rods sticking through the vinyl.
I have never seen a seat do that ,Im in to see what you find out from those that have been there and done that .
flashed is offline   Reply With Quote
Old 02-13-2015, 11:12 AM   #3
The Swed
The Swed's Avatar
Well with no input from anyone I will proceed and smooth those rods down and cover the seat tonight. I will report out on how it when complete.
Old 02-13-2015, 11:18 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by The Swed View Post
Well with no input from anyone I will proceed and smooth those rods down and cover the seat tonight. I will report out on how it when.
I didn't see this post until now. I don't think I would do that. You may need those ends to re-attach the springs.... Look on the back to see where they were attached. I will check one of my seats when I go out and see if I can see anything.
LockDoc
Leon
Old 02-13-2015, 11:56 AM   #5
The Swed
The Swed's Avatar
Good point! These rods are welded to the tube that runs the length of the back support and the foam is in front. The height of that rod to the post is about .180". If you look closely you can see the weld fillet on the rod to the tube.
Old 02-13-2015, 12:11 PM   #6
LockDoc
LockDoc's Avatar
If that's the case then I can't see why you would need them. I have never seen that happen either. I get the feeling someone screwed up when putting the seat together. Grind away!!!!..
LockDoc
Leon
Old 02-13-2015, 12:15 PM   #7
The Swed
The Swed's Avatar
I agree, thanks Doc.
Old 02-13-2015, 01:05 PM   #8
flashed
Keep us posted on this and let us know how it turns out .
Old 02-13-2015, 01:07 PM   #9
flashed
And just a suggestion going forward ,if you dont get a response to a question ,just take your post back to the top of the page so folks like LocDoc will see it .
TTT
Old 02-13-2015, 01:56 PM   #10
jimbosprint
jimbosprint's Avatar
I was told it's a good idea to round them off when re-covering the seat.
jimbosprint is offline   Reply With Quote
Old 02-13-2015, 01:58 PM   #11
The Swed
The Swed's Avatar
Thanks Flashed I'm new here so I appreciate the heads up.
Old 02-13-2015, 02:00 PM   #12
The Swed
The Swed's Avatar
Thanks Jimbosprint!
Old 03-05-2015, 12:00 PM   #13
The Swed
The Swed's Avatar
Update... I haven't tied down the seat cover yet and I will have the seat completely redone when in a year or so. To many another things needed like brakes and transmission repair. I did grind down the rods and it appears to be a nonissue now. Thanks for the help. BTW I did insulate the floor while the seat and tank are out.
Old 03-05-2015, 01:06 PM   #14
flashed
Looking better there .
Old 03-05-2015, 01:30 PM   #15
The Swed
The Swed's Avatar
Old 05-02-2016, 03:04 PM   #16
The Swed
The Swed's Avatar
Thumbs down Re: Bench seat question, rods sticking through the vinyl.
Installed! Life is good!
Old 05-02-2016, 09:18 PM   #17
flashed
Seat looks really good .
Old 05-03-2016, 11:13 AM   #18
LockDoc
LockDoc's Avatar
That should last for quite a while. Looks great!
LockDoc
Leon
