Old 02-12-2015, 03:32 PM   #1
The Swed
The Swed's Avatar
Bench seat adjustment missing a part?
I believe there should be a spring on the passenger side to hold this adjustment pin in a locked position once the tension is removed. I'm not sure that the adjustment rod is routed correctly because it seems rather loose.
1970 C20 350/TH350, LB
God Bless our Troops
The Swed is offline   Reply With Quote
Old 02-12-2015, 09:14 PM   #2
clemsonteg
Re: Bench seat adjustment missing a part?
I can't comment on the spring. I used this thread to modify my seat because my rod was all bent and didn't work right http://67-72chevytrucks.com/vboard/s...&postcount=263
clemsonteg is offline   Reply With Quote
Old 02-12-2015, 09:50 PM   #3
brian1971
brian1971's Avatar
Here are a few pics from a original seat from a 71 c10.
Pics are of passenger side adjuster.
Brian
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 02-13-2015, 11:07 AM   #4
The Swed
The Swed's Avatar
clemsonteg great fix, thanks!
brian1971 that's the image I needed, thanks!
I believe the seat adjustment rod connects under the seat buy running through that metal clip in the middle which is why it's so loose now. Seems a strange way to do it. I may be missing something.
Old 02-13-2015, 11:31 AM   #5
hamjet
hamjet's Avatar
found this on the site. used to take up slack on the rod..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 02-13-2015, 11:38 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
One of mine had a "S" hook that hooked on the rod and on the back edge of the seat. Here is a scan from a parts book.
LockDoc
Leon
Old 02-13-2015, 11:42 AM   #7
LockDoc
LockDoc's Avatar
Joe,
That one is from my Blue '67 Chevy. It works great with the "Z" bent connector rod but I think it would allow too much movement on the straight connector rod and wouldn't allow the passengers side to release.
LockDoc
Leon
Old 02-13-2015, 12:08 PM   #8
The Swed
The Swed's Avatar
Great info, thanks!
Old 02-13-2015, 06:26 PM   #9
hamjet
hamjet's Avatar
Yeah Leon, I did a search but couldn't find the right one. I knew I saw it somewhere before..
Thanks, Joe..
Old 08-20-2015, 05:42 AM   #10
jr1966
Great info and pics. Having the same problem putting mine together.
Problem is now solved .
jr1966 is offline   Reply With Quote
