Wiper ground
On a 57 factory electric wiper setup, do I need to run a ground wire or will the mounting in factory brackets suffice or the ground?
Re: Wiper ground
That is a good question
I believe the units were internally grounded (grounded off the cab mount) but if your motor housing or mounts are rusted you may want to attach a ground wire to be sure.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside |
Re: Wiper ground
Yes, wiper body grounds thru the bolts to the cab. rust or fresh paint will keep it from grounding. If painted chase the threads with a tap. If rusted add a ground wire from housing bolt to good bare metal.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Re: Wiper ground
Here are some pictures from my 55.2 wiper motor that I finished working on recently. It does need a ground wire if you have the rubber vibration grommets installed. Maybe the mounts changed by 57, I'm not sure but a ground wire wouldn't hurt.
Earl
You have to have patiences or you'll be one. |
