02-12-2015, 08:19 PM | #1 |
meowMEOWmeowMEOW
Whats the hardest part of Tube Chassis builds?
Say a guy has some welders, and some DOM tubing or box...how hard is it really to build a tube chassis (or backhalf even for discussion)?
To me it would appear a lot like doing a cage, but a lot more time intensive and waaay more sensitive to plumb/level/square. You don't see a ton on DIY tube chassis for certain obvious reasons, like not killing yourself...but I know its something a competent hotrodder and welder should be able to do .
02-12-2015, 08:43 PM | #2 |
Re: Whats the hardest part of Tube Chassis builds?
I am going to comment halfway just to subscribe and see what input there is.
Between me and my neighbor we have everything we need to do something like this (mig/tig/compressors/benders/fab table). Might not do it on my 75 but by the time I get to my 66 I would be interested and going much more custom.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
02-12-2015, 10:46 PM | #3 |
The cage part is easy from my experience. Dont bother with DOM. Go straight to Chromoly so if you want to go faster in the future, you can just add on and not completely rebuild. I think NHRA puts out a book with all the critical specs, angles and tube sizes for each cert.
As far as back half that a whole nother ball game. tons of geometry to get things right. So many factors go into a rear suspension set up and its pretty easy to miss. Especially on a small tire and 1000+hp. But thats just my take. This should be a great topic. I like this section here on the boards. |
02-12-2015, 11:19 PM | #4 |
I've seen back-half and chassis cars that were half ass and some that were middle of the road and some that are stellar.
You need a chassis plate or its really never going to be what it should be. By that I mean your doing the back half or chassis to improve over factory suspension. People are running stupid fast with stock suspension parts, drag or road racing. To achieve an improvement the work needs to be 100% perfect otherwise your kind of wasting your time. All that said Ive seen a couple 70's and 80's cars that were rotted out, frames, floor boards etc. and the builders did a mild steel back half (on their garage floor) to save the car and put it into the local bracket class running 9's or 10's. Nothing wrong with that. |
02-13-2015, 01:20 AM | #5 |
60-66 Nut
On a street driven truck I would use DOM over 4130 (Chrome Moly). IMO it just isn't worth the added expense and the extra time for a perfect fitup and to TIG it all.
If you're really serious about building a complete tube frame, I would highly recommend investing in Bend Tech Pro software. That way you can design the entire chassis on the computer before you cut or bend a single piece of tube.
02-13-2015, 01:32 AM | #6 | |
meowMEOWmeowMEOW
Its not a project thats high on my priority list, but a number of times I've regretted going "small" on projects and doing them 2-3 times. I really like the trailing arm rear that I have, so I think the benefits I see would be overall chassis stiffness and some weight loss. I've only welded cage chromoly a few times, not a pro with the stuff ($$ too much to experiment with). DOM steel, and SS I'm comfortable with tho. I'm guessing the answer is Dino, but anyone here done a home setup tube chassis?
02-13-2015, 01:33 AM | #7 |
meowMEOWmeowMEOW
While sometimes not THE most active place on this forum, most of what comes out of here is good content. Most of the threads actually contain useful experience, and less rehashing than I expected.
02-13-2015, 07:52 AM | #8 |
mini truck racer
2 reasons to go chromoly future resale , weight reduction and smaller size of tubing . Ok thats 3 sorry . I have been told a current 8.50 cert is worth $1000 easy in resale .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
02-13-2015, 09:51 AM | #9 |
Registered Truck Offender
I've done a few mild steel backhalf's with kits, but have not and WOULD NOT tackle a full chassis as a backyard project. But that's just 'ME',, your ambition may vary.
The only way I can see to do it without having a complete race car fab shop with a jig set up for building CM chassis would be the kits like the Alston or Bickel 'buy it all here' packages. And then you better have the proper tube notchers and benders,, and plenty of extra material. If it were a 'complete tube chassis' I wouldn't touch it unless I had a BIG space with a SOLID fab table specifically for chassis building. With out a jig things are going to warp and twist and end up with something that is... well ,,, Just having all the bars necessary to get a 25.x cert doesn't mean a vehicle really is 'safe'. Once you've been sub 10's in a car that doesn't want to go straight.... or one that consistently upsets the chassis in the shutdown or any 'quirk' that can be the result of a twisted chassis... you'll wish you built a pro-built chassis.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
02-13-2015, 12:18 PM | #10 | |
As for the garage build, dont be that scared. A table is simple to build and fairly cheap. lots of clamps and wear out a few tape measures. and it sounds like your partner has some fun toys to play with. How fast do you see yourself going in the future? |
02-13-2015, 02:01 PM | #11 |
It's Better With Nitro
I've built several full chassis cars in my garage from my Super Gas car to my current funny car. The common denominator has been a chassis jig and paying very close attention to plumb and level, as well as clearly establishing ride height. If you're planning on building a SFI spec chassis, I highly recommend buying the SFI documentation (this is what I did for a FED build and my current chassis).
02-13-2015, 05:57 PM | #12 | |
meowMEOWmeowMEOW
Within the next couple seasons I'd like to start aiming for 10 flat and realistically aiming for under 10.50 I don't have any intention of really being a sub 8.50 vehicle EVER, and even getting down there may be a life ambition with this truck. If I could buy a full fiberglass body and start over building a clone (ala evil twin) I would. I just was reading the rules for the Heavy Iron classes and thought the all steel body with a tube chassis is a cool idea. The goal for the T/A is 8's, but the exponential costs under 9.50 will very possibly prevent that for at least a few more years. He can source way more funding than I can, I'm just wrangled in to do the fab and such.
02-14-2015, 03:07 AM | #13 |
meowMEOWmeowMEOW
BTW, an apparently you can just buy the blueprints from Alston...so making a chassis off of proven plans is far less intimidating.
02-20-2015, 07:19 PM | #14 |
hmm maybe guilty by design fab has some input, he built a tube chassis for an ad truck. mines over there right now waiting on wheels and tires, hes building me a full tube chassis. dont ask specs because we havent decided on details just yet
02-15-2016, 07:31 PM | #15 | |
Saw a 60's era Truck tube frame chassis here locally. This is the guy Im selling parts for.
My Build: 57 Chevy Pro-Street |
02-15-2016, 07:40 PM | #16 |
meowMEOWmeowMEOW
Thats pretty sweet.
02-16-2016, 06:40 AM | #17 |
Active Member
It's all about setting a realistic goal and going for it. A tube chassis is generally used in an all out race car. The SFI 25.3 spec is what to get if your going that 4130 route. Once you go down that road your going to need big bags of money and time, and oh yea... if your married set aside some geets for a divorce lawyer. The fab part is not that hard if you have a table or jig and some tig experience. Your gonna want to have your own tube bender and notcher to do minor tweaks... even if you purchase a chassis kit. It's actually easier to just buy some tubing, understand the spec and design your own if you have the tools. My advice is to do a 4 link back half if you want to have some fun with fab stuff/chassis setup... keep having fun with your truck. Keep it on the street and have some fun at the dragstrip when you can. last... there's lots of aerodynamic race cars out there for sale.. cheap comparatively. Feeding one is why they are up for sale. Last edited by Gary V; 02-16-2016 at 06:54 AM. |
02-16-2016, 10:52 AM | #18 |
Boosted Member
Which half? The back-half?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
02-16-2016, 11:58 AM | #19 | |
Additionally (to me, anyway) another hard part is that you are required to provide EVERYTHING: every nut, bolt, bracket, brake, etc. It's not like re-doing an existing chassis where you can reuse some of the detail parts. K Friend of mine that lives down the street:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-16-2016 at 03:16 PM. |
02-16-2016, 12:52 PM | #20 | |
Posted via Mobile Device |
02-16-2016, 12:56 PM | #21 |
Chassis
Purgatorio |
02-17-2016, 03:55 PM | #22 |
Tiddlar - just for ****s and grins.... how many hours are in that chassis alone and what was the material bill? just chassis, nothing else.
And this is mild steel? or chromo?
