02-12-2015, 08:42 PM | #1 |
radiator leaks
So, I have this leak here right that is seeping between the threads.. Is there some type of seal that goes here. I was just winging it and tried so thread lock tape which did none thing. .
02-12-2015, 09:10 PM | #2 |
Re: radiator leaks
Well that is for the oil cooler lines. If its seeping out from behind the large nut then you need a new rad or get it repaired. There is no real fix for that unfortunately except a new end tank.
02-12-2015, 09:17 PM | #3 |
Re: radiator leaks
Ok thanks. .. I done use that side for anything just started leaking. .. I guess I'll have to get it fixed some time. . Shops here fix them for 70 bucks. .
