![]() Join Date: Jun 2010
Ruined the cluster panel by using a cleaner.
I forgot to put this on here the other day. I was using the cleaner called Awesome while swapping interior in the short bed. I was mainly using it to clean any metal surface while I any plastic trim off. While I had the dash pad off I was spraying some of this cleaner and some of it had sprayed onto the cluster panel. I took a rag to start to wipe it down and clean the panel in the process. I quickly realized this was going bad very fast. Here are the results. Where I wiped the finish came right off. Then there was the spray spots that I didn't even touch after seeing what would happen if I tried to wipe it.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
