02-13-2015, 10:09 AM | #1 |
POL upper tubular a arms- did I install them correctly?
I bought these several years ago and installed them, but they didn't come with any directions, and there is no tech articles on POL's website that show installation of these. I haven't had the truck on the road yet, so I haven't had the front end aligned, but I keep wondering if I put these on right. I guess they could be installed about four different ways! Any thoughts if these are on right?
02-13-2015, 10:52 AM | #2 |
Re: POL upper tubular a arms- did I install them correctly?
Just looking at the pictures its hard to tell. Almost looks like the may be swapped side to side. A caster measurement would tell you quickly.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-13-2015, 10:56 AM | #3 |
I know visually, it looks like the top of the tire is tilted outward more than the bottom. I can only adjust it outward, no way to bring it in more.
02-13-2015, 11:56 AM | #4 |
Never Ending Projects
Comparing to stock, it seems like you have them correct. It seems the "straighter" side is to the front of the truck. The more "bent" side is to the rear.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
02-13-2015, 01:57 PM | #5 |
Top in or out is camber. The tilt of the top of the spindle is caster. Needs to be 4 or 5 degrees positive and that moves the top to the back of the truck.
Jimmy
