02-13-2015, 02:10 PM | #1 |
While the tank and bench seat are out should I Insulate?
The cab gas tank is out and the bench seat too. Should I place some heat shield insulation down in the back of the cab and floor before I put the tank and seat back in? If so is the insulation at the local hardware store acceptable?
1970 C20 350/TH350, LB God Bless our Troops |
02-13-2015, 02:19 PM | #2 |
Old member
Re: While the tank and bench seat are out should I Insulate?
I did and I put Hush mat down first then covered it with foam insulation and carpet! My tank doesn't go back there though anymore!
02-13-2015, 03:32 PM | #3 |
Do it ,You will appreciate the extra quiet.
02-13-2015, 03:39 PM | #4 |
Will do!
02-13-2015, 03:53 PM | #5 |
X2. Do the inside of the doors also.
1970 C10 Short Stepper with 71/72 front clip. |
02-13-2015, 04:02 PM | #6 |
Great idea I have to replace some of the worn out parts on the inside of both doors next week so I'll do it then.
02-13-2015, 09:05 PM | #7 |
Is this the right stuff?
02-13-2015, 09:07 PM | #8 |
this is the perfect time to do it.you will notice the difference
02-13-2015, 09:29 PM | #9 |
I'm still not sure this is the stuff... I'll wait to buy it after I get some feed back.
02-13-2015, 09:52 PM | #10 |
Old member
That's what is in my picture!
02-13-2015, 10:02 PM | #11 |
Good! Did you use the 48' or the 24' ?
02-14-2015, 07:07 AM | #12 |
Old member
I don't remember!
That's just to many ages ago now!
02-14-2015, 07:12 AM | #13 |
If you do the doors, don't cover the drain holes in the bottom, its the only way to let moisture out.Dave
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build http://67-72chevytrucks.com/vboard/s...d.php?t=589869 |
02-14-2015, 07:15 AM | #14 |
you can get a foil back insulation at lowes called peel and seal, its in the roofing area. it will take about two rolls to do your truck. I would also buy a couple rolls of foil tape to seal the edges and seams with
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
03-05-2015, 11:51 AM | #15 |
Update, Slow but steady...
03-05-2015, 09:17 PM | #16 |
^^^^^ That's looking good . I plan to do that to mine once the weather here allows it.
1971 C10 SWB ...project in the works 2000 Camaro SS....weekend warrior/racecar 2005 Caddy EXT....Tow rig |
03-05-2015, 09:29 PM | #17 |
That was money well spent you will be happy you did it.👍
03-05-2015, 09:42 PM | #18 |
Does that stuff compare with dynamat or hushmat? I plan on doing mine also... don't need to spend a fortune, but don't want to do it twice either.
03-05-2015, 10:40 PM | #19 |
I insulated mine and added acoustic foam panels to the tank, helps absorb reflections in the cab. Made a big difference.
http://smg.photobucket.com/albums/v655/aaronhero/ |
03-05-2015, 11:59 PM | #20 |
I used the peel & stick aluminum coated flashing from home depot. It is 6" wide and less than an eighth of an inch thick. It took a little over one roll. I think a roll is about $20.00. It made a big difference because it dampens a lot of the harmonic noise from the floor boards. I read somewhere (perhaps on this site) that you can line the inner door skins too.
03-06-2015, 02:36 AM | #21 | |
______________________ www.northeastrodrun.com |
03-06-2015, 11:32 AM | #22 |
While seat and tank are out is the very best time, GO 4 IT !!!
03-06-2015, 12:07 PM | #23 |
Do you know how exciting this is!!!!! My guys use both of those products for winter time insulation and its givin to us for free. Better than Xmas
what about that little guy? That little guy??!! I wouldn't worry about that little guy |
03-06-2015, 12:09 PM | #24 |
Is this stuff OK to use inside doors that will wet?
03-06-2015, 12:51 PM | #25 |
