Old 02-13-2015, 04:20 PM   #1
hanly2
Removing front springs
Ok so last time I did this on my 2003 Silverado, I was using the spring compressors and they were a joke, I just ended up putting the jack on the lca and unbolting it at the frame. So I checked under the 70 and it looks like the lca is bolted on using those 4 u bolts. Is that correct? Has anyone ever removed the springs using that method on one of these trucks? Last time I tried unbolting a spindle I destroyed all the rubber boots everywhere.
hanly2 is offline   Reply With Quote
Old 02-13-2015, 04:30 PM   #2
Mike C
Mike C's Avatar
Re: Removing front springs
On my truck I just loosen the nut on the lower ball joint and split it with a pickle fork. Put jack under LCA and jack up until load off nut. Remove nut, lower LCA, remove spring.
When you put it back on that way it goes straight up and you don't have to jockey the u-bolts on the crossmember which is a PITA.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-13-2015, 04:50 PM   #3
aod92
aod92's Avatar
I just took mine out yesterday. I put a jack under the lca and take the nut off the upper ball joint. Give it a couple good hits with a hammer until the top seperates and then I let the jack down slowly.
aod92 is offline   Reply With Quote
Old 02-13-2015, 04:53 PM   #4
hanly2
With all the rust around here those things never break loose, and the pickle fork part is where I tore the boot.
Old 02-13-2015, 04:53 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Same here. I haven't use a pickle fork in 30 years. Just a BFH.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-13-2015, 04:55 PM   #6
RodnRudy
RodnRudy's Avatar
Rather than using a pickle fork and taking a chance of ruining the rubber boot, loosen the castle nut about three turns and use a BFH hitting the spindle where the ball joint goes through. You can see when the ball joint pops loose. Then raise the LCA with your floor jack, remove the nut the rest of the way and let the LCA down and remove the spring.
RodnRudy is offline   Reply With Quote
Old 02-13-2015, 04:57 PM   #7
RodnRudy
RodnRudy's Avatar
Oops, I typed my response so slow three others beat me to it. LOL
Old 02-13-2015, 05:31 PM   #8
cdowns
cdowns's Avatar
I like replacing the ball joints so destroying the rubbers aint a big deal
Old 02-13-2015, 05:50 PM   #9
hanly2
Ok so remove the top nut or the bottom nut? some mixed responses here
Old 02-13-2015, 05:59 PM   #10
Mike C
Mike C's Avatar
Bottom for me. I think it gives more clearance to get the spring out. And you can raise the upper and block underneath it to hold everything out of the way and the brake hose is plenty long for that.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-13-2015, 06:29 PM   #11
Tango59
I just replaced my springs shocks and ball joints... Wish I would have done the ICA bushings too... The new Moog Springs were not wanting to compress in the CA without the jack rocking the truck too far on the jack stands so I used a big C clamp on the control arms to help compress it enough to bolt everything back up.
Tango59 is offline   Reply With Quote
Old 02-14-2015, 12:00 PM   #12
aod92
aod92's Avatar
I remove the top. Once you lower the bottom control arm the spring practicaly falls out.
Old 02-14-2015, 12:29 PM   #13
GRX
GRX's Avatar
As an aside ... I like to use a cable bike lock to ensure the springs don't fly out and break themselves on my head.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 02-14-2015, 05:03 PM   #14
hanly2
Im putting bags in so I dont have to worry about compressing the new spring. I will probably chain it to the frame to be safe.
Old 02-14-2015, 06:15 PM   #15
Possmguts
Possmguts's Avatar
Not to hijack this post but when re-installing the lowers... how do you know when the they are in the right place before tightening the U-bolts? I see nothing that indicates when the lowers are slid forward or back at right position.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 02-14-2015, 07:17 PM   #16
69SCSS
69SCSS's Avatar
I have that Ball joint removal tool that works great, so I just loosen the bolt on the bottom ball joint and thread the nut up, slap the tool on there and it pulls out, then lower the jack very slowly. I agree the U-bolts is a pain. I used a ratchet strap and wrapped around the spring and the crossmember, so the spring can't move. My springs are cut so I don't have to drop it all the way down for them to be loose.
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 02-15-2015, 01:23 AM   #17
mechanicalman
X2, or my long pry-bar, long extension, or a piece of chain. Just in case you slip you don't want all that stored energy doing a Mike Tyson on you.
mechanicalman is offline   Reply With Quote
Old 02-15-2015, 01:37 AM   #18
Blown06
Blown06's Avatar
There's a dimple in the cross shaft that should align with a pin on the cross member, you won't see it until you unbolt the u bolts holding the LCA in place. Look at post #5 in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=623839
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
