Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-13-2015, 07:06 PM   #1
youngblood78
4.3 distributor question
Ok so I have a 92 chevy s10 that a friend of mine was doing a v8 swap well he ended up scraping the project and sold everything he had to me but the original 4.3 I dont have time to go thro with the v8 swap so im just going to put a 4.3 back in.. I have one in a 93 full size I need to know the difference between the full size and the s10 4.3 thank you
94 Silverado 1500 ext. Cab short bed 350 nv4500 (factory)
78 K20 350 (soon to be 400sbc if I can find one) sm465 205 dana44 14bff 6in lift on 37" militarys
youngblood78 is offline   Reply With Quote
Old 02-14-2015, 02:15 PM   #2
terry b
terry b's Avatar
Re: 4.3 distributor question
Not much on the back of the motor. But front is a different story.
terry b is offline   Reply With Quote
Old 02-14-2015, 09:12 PM   #3
youngblood78
How so?
Old 02-16-2015, 11:36 PM   #4
youngblood78
Can any one help me with this?
Old 02-20-2015, 09:40 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
93 C/K engine into a 92 S/T truck? Both are 4.3 throttle body injected? Or did the S10 originally have a CPI system? TBI is a VIN code "Z" while CPI is a "W". 8th digit of VIN
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 02-20-2015, 07:48 PM   #6
youngblood78
No its just a tbi truck nothing fancy other than switch controlled 4x4 I know the motors are the same just a question of accessories like distributor and front pullys and all
Old 02-20-2015, 07:51 PM   #7
youngblood78
On the other hand what is the difference between a 89 and 92 both S series 4.3 motor just as far as electronics
Old 02-21-2015, 07:44 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
both are same size, shape and bolt holes everywhere
Old 02-23-2015, 09:44 AM   #9
rickywideglide
rickywideglide's Avatar
you might find different connecters on t.b.i,i swapped a 90 4.3 into a 91 w/t one connecter was different i think t.p.s sensor
rickywideglide is offline   Reply With Quote
Old 02-25-2015, 02:19 AM   #10
youngblood78
Ok thank for the input
Old 04-24-2015, 09:49 PM   #11
hugger6933
Only difference tween the S/T 4.3 and the C/K 4.3 is the exhaust manifolds, they fit in closer to the block on the S truck. The ACC drive is the same as well because I've swapped both ways when I had a lot of spare parts, I used to rebuild both the small and big trucks from wrecked and had probably 30 or so S trucks on hand for salvage and tried to keep around 15 to 20 full sized for salvage at the same time. They are almost all gone now as I used up a bunch of the parts and crushed the rest[I built like 15 trucks in a row without buying outside parts other than windshields]. Trucks are way too high to have salvage like that laying around now. Jim
hugger6933 is offline   Reply With Quote
Old 05-23-2015, 10:20 PM   #12
Hoosier Rick
s10 4.3 4x4 has a different oil pan for front diff clearance.
Hoosier Rick is offline   Reply With Quote
