Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-14-2015, 01:14 AM   #1
lwb82c10
what would I need to go from a small block to a big block
I have a 82' C10 with a small block , I wanna know what would I need to change to go from a small block to a big block
LWB 82 c10 building a street/strip truck. has a 468 with stock 12 bolt.
lwb82c10 is offline   Reply With Quote
Old 02-14-2015, 01:43 AM   #2
Captainfab
60-66 Nut
Re: what would I need to go from a small block to a big block
What kind of realistic power will the big block be producing? What will need changed will also depend on just what you have with your small block. For starters, you will likely need to change the radiator and shroud. Unless the TH350 is built for the increased torque, you might be best off to upgrade to a TH400.
Old 02-14-2015, 01:50 AM   #3
lwb82c10
i'm doing a new cooling system and i'm doing a new fuel system,looking at th400, the big block will have 400-420HP 480-500TORQUE
Old 03-05-2015, 10:29 AM   #4
rickpilgrim
In my 82 I needed:
Radiator/fan/shroud
Engine accessory brackets for BBC
Engine
Throttle cable
TH400 or TH475B with 4" tail shaft
New transmission cooler lines
After market TH400 kickdown switch
Custom Driveshaft with TH 400 yoke to 12 bolt saddle
Once you have all that and a tiny bit of wiring you'll be good to go.
rickpilgrim is offline   Reply With Quote
Old 03-05-2015, 04:52 PM   #5
pistonbroke800
pistonbroke800's Avatar
I'm doing a SB to BB swap right now. Why was the throttle cable swap needed? Thanks in advance
pistonbroke800 is offline   Reply With Quote
Old 03-05-2015, 06:15 PM   #6
rickpilgrim
First is if you set them side by side the big block cable is about 1" longer. You may not need to on your truck but my big block had a performer style intake. Of course there's also the 30 + yr old factor and nothing ruins your day like either a stuck cable at WOT or no connection at all because it broke.
