Real Newbie question regarding the removal of A Arm bushing...
Gentlemen
Whilst not new to Cars, i am new to the particular 'nuance' of the 66 C10. I see that the A Arms do not employ a bush in the traditional sense. I need to remove the 'pivot arms' (best description I could come up with). What is the best ay to go about this? Do I need any special tools? As they are out is there anything I should be looking for or do with them? P. ![]() |
#2 | |
Re: Real Newbie question regarding the removal of A Arm bushing...
Inspect them. If they don't appear in bad shape, clean them up & re-use them if the seals look good. When you re-assemble, thread each side onto the a-arm shaft as evenly as possible. Snug them gently (no torque). Once the truck is on the ground w/the suspension loaded, then do your final tightening. This keeps the bushings from being pre-loaded.
