02-14-2015, 09:42 AM | #1 |
How to plug hole in exhaust pipe
One inch long, maybe 1/8 inch wide rust hole in exhaust pipe I want to fill until I get new pipe. Why? The sound is "flubbing" and I really like the sound of the v8 so I want to plug up the hole. Rust, heat. Any products out there that would work? Thanks ahead of time for the help.
02-14-2015, 09:45 AM | #2 |
Re: How to plug hole in exhaust pipe
put a band clamp around it
"Negative people always seem to have a problem for every solution" |
02-14-2015, 09:48 AM | #3 |
they are all temp, repairs , best to cut out bad and replace piece, but to band aide it take a soup can and knock ends out , split side , wrap around pipe , put a couple hose clamps on it and you have a metal band aide this is just a temp type repair
02-14-2015, 09:52 AM | #4 |
Not the best way, but quick and affective.
Try to find some header wrap, or fiber cloth and band clamp it around the pipe. Wrap it several times around the pipe, right at the hole so you have three or four layers. Or, if you can weld take a piece of pipe and scab over the whole, then stack tacks till its welded out. Thats even better!
I just gotta get out here and do it, why? Cause nobody will do it for me... |
02-14-2015, 10:00 AM | #5 |
Roadtrip!
Go to your local parts store and get the wrap that goes around the pipe and sets up after it gets hot. Actually made for your situation. I think it was under $20 last i used it.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-14-2015, 10:55 AM | #6 |
weld it shut if the surrounding pipe is good. best way to fix it and will last the longest.just take your time so you dont burn more holes in it
02-14-2015, 11:39 AM | #7 |
pop can and a couple of hose clamps.. i'll fit it temporarily.
02-14-2015, 11:43 AM | #8 |
laying low
I think 3m and others make exhaust pipe joint sealer. Comes in a tube. You could cut a piece of metal 1" or so larger than that hole, grind or sand the area around the hole, apply joint sealer between the two then clamp them together. It's cheap and no welding required. The sealer should be available at any auto parts store.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-14-2015, 12:05 PM | #9 |
#16876
I had the same issue on my truck and stopped at a small muffler shop. They guy chopped out a section, replaced it and refused payment. Fast forward I had a broken hanger that needed to be welded. Same thing no charge. I'd bet if you roll in a shop at a slow time they'd be willing to patch it up cheap.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
02-14-2015, 12:35 PM | #10 |
Been there, done that. But these days a soup can would be a better candidate since all pop cans are thin aluminum these days. Down here is the states anyway.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
02-14-2015, 05:58 PM | #11 |
You guys are great. I like boogs idea since I just want to squeeze some goop into the hole and seal it. Yes I'm lazy, it's a small hole and eventually I'll replace the whole pipe. Thanks
02-15-2015, 01:19 AM | #12 | |
You will get it done either way/s. |
02-15-2015, 01:20 AM | #13 |
02-15-2015, 08:48 AM | #14 |
02-15-2015, 10:06 AM | #15 |
I agree with the shop idea. I know my local guy wouldn't charge me more than 20 bucks. Wouldn't hurt to stop in and see. Never know, the shop guy might be a big fan of your truck and hook you up!
