Old 02-14-2015, 10:48 AM   #1
rs74
rs74's Avatar
Where can I get new wing vent handle gaskets?
Took the short bed for its first drive yesterday and noticed the vent windows were leaking air pretty bad. The gasket between the handle and glass seems to be all wore and not able to put enough pressure when the latch is against the frame when closed. Also I haven't looked yet but is there a set screw on the handles to take them off ?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-14-2015, 03:25 PM   #2
rs74
rs74's Avatar
Re: Where can I get new wing vent handle gaskets?
After looking a little closer it looks like they are just spring washers in there. So maybe I just need to see if I can tighten things up maybe.
Roy
1987 R10 shortie
Old 02-14-2015, 03:25 PM   #3
TKCR
TKCR's Avatar
This place has a lot of stuff for the vent windows
http://www.classicparts.com/Misc-Gla...oducts/384/3/0
Old 02-14-2015, 04:11 PM   #4
rs74
rs74's Avatar
I am not even sure what all is supposed to be in there. Here is what I have now.
Roy
1987 R10 shortie
Old 02-14-2015, 05:19 PM   #5
68Timber
I know the pieces fit
68Timber's Avatar
I saved the instructions when I got a new set for the CUCV.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-23-2015, 04:59 PM   #6
rs74
rs74's Avatar
I found a dorman latch but only for the drivers side. I can't find the # for the passenger side. I am trying to order the majority of my parts from one place and can not find this number to see if they have it.
Roy
1987 R10 shortie
Old 02-23-2015, 06:30 PM   #7
TKCR
TKCR's Avatar
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=19
Old 02-23-2015, 06:33 PM   #8
rs74
rs74's Avatar
I will probably have to order a set from one of the links you posted. I am putting an order together from Rockauto and was just going to try and get them through there but they only list the left side.
Roy
1987 R10 shortie
Old 02-23-2015, 09:00 PM   #9
MikeB
MikeB's Avatar
You might try a local parts store. I bought a rebuild kit for my 82 at Autozone.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-23-2015, 10:06 PM   #10
burkeftm
gm part numbers should be 12300197 and 12300198 nos are on ebay now they are running about 30.00 each side
Bob
burkeftm is offline   Reply With Quote
Old 03-03-2015, 11:48 AM   #11
rs74
rs74's Avatar
I ended up buying a passenger side replacement from Napa for $18. It came with an extra set of springs and gaskets in case I was working on a van. Apparently they are a little different thickness on the vans. I am going to use the extra parts to try to tighten up the drivers side. If that don't work then I will buy another new one.
The new latch helped bring the noise down but still have a little left. Probably needs a new window gasket but I am not sure I am going to mess with that right now. It is quieter in the cab now but that also allowed me to hear other places that are leaking air going down the road. Not sure if the rubber on the door jam or the top felt is leaking on the drivers door but it is right next to me.
Roy
1987 R10 shortie
