Old 02-14-2015, 11:11 AM   #1
mattcrp1
mattcrp1's Avatar
Coolant temp sender idea
Hi all, I have been trying to figure a way to install my factory temp sender for the dash in my '76 with out being to intrusive. I tried to turn down a sender and cut threads into it and the sender was to thin. I don't want to drill and tap the head or the water pump, but I remembered that some ford products had a temp sender/switch in the heater hose like this one pictured. I figured I could cut the tube, flare the end and install it in line. Anyone have pro/con's about going this way?
Thanks,
Matt
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
