Old 02-14-2015, 02:47 PM   #1
miller.joe.b
Camaro rear end?
I have been pondering the idea of putting a posi rear end in my 1970 c10. At one point someone had mentioned to me that many Camaro rear ends would be a fairly easy swap. I came across this link and was wondering if this is a feasible solution: http://houston.craigslist.org/pts/4881149781.html
I know this is only a 10 bolt, but I am not putting out any ridiculous amounts of power. I have a freshly rebuilt 350 with vortec heads, mild cam, and a 4 speed muncie. If this is not what I should be looking for, then what? I am not looking to break the bank and don't mind taking the time to rebuild something. Wouldn't mind switching over to disc brakes in the process either. At the end of the day I am looking for a posi-trac rear end without spending a ridiculous amount of money. Any help is appreciated.
miller.joe.b is offline   Reply With Quote
Old 02-14-2015, 02:53 PM   #2
frankslagoon
Re: Camaro rear end?
There should be lots of used c10 rearends w/posi kicken around out there. that would be the easy way and probably about the same price.
frankslagoon is offline   Reply With Quote
Old 02-14-2015, 02:58 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You will have to do a lot of fab work to get that to fit. Cutting off perches and welding on new ones. New shock mounts need to be fabbed. There is no provision for a pan hard rod either.
Also... if you do find a 12 bolt out of one of these trucks in a bone yard... chances are the Posi-traction unit will be pretty much worn out and need new clutches anyways.
Just do yourself a favor and spend the bucks on an Eaton Posi-traction unit to put in your existing truck 12 bolt. It will be the best 400 bucks you can spend on your truck. After you spend the money on that 10-bolt, fab everything up. you'll be into it for the same money as putting in the Eaton unit.
You couldn't pay me to switch to a late model 10-bolt.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-14-2015, 05:35 PM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Originally Posted by gasoline71 View Post
you will have to do a lot of fab work to get that to fit. Cutting off perches and welding on new ones. New shock mounts need to be fabbed. There is no provision for a pan hard rod either.
Also... If you do find a 12 bolt out of one of these trucks in a bone yard... Chances are the posi-traction unit will be pretty much worn out and need new clutches anyways.
Just do yourself a favor and spend the bucks on an eaton posi-traction unit to put in your existing truck 12 bolt. It will be the best 400 bucks you can spend on your truck. After you spend the money on that 10-bolt, fab everything up. You'll be into it for the same money as putting in the eaton unit.
Gary
+1!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-15-2015, 03:15 PM   #5
Fitz
If your truck already has an 8.875T rear, what most folks call a "12 bolt truck" it's easy to upgrade it to a posi rear. A differential has 7 moving parts, they aren't difficult to change the carrier from an open to a posi so why mess with a swap? Drive Train Specialists has an Eaton posi for your truck for $420.00. You probably need the shim kit to get the backlash right but that's another 30.00 or so. The only other thing you need is the chassis overhaul manual to guide you through it. That's another $30.00 from motorbooks.com
Fitz is offline   Reply With Quote
Old 02-15-2015, 10:22 PM   #6
cooperhw
cooperhw's Avatar
Well explained. lot of work to get something in there that doesn't want to be there. Doable, but not much fun. Emergency brakes are another hassle.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 02-15-2015, 11:56 PM   #7
doubleb's69
doubleb's69's Avatar
Don't forget the camaro will have a 4.75 bolt patern. Truck is 5 on 5. Gasoline71 nailed it.
Bud
doubleb's69 is offline   Reply With Quote
