02-14-2015, 02:59 PM | #1 |
Driveshaft shops in Los Angeles area
Can anyone recommend a shop for a new rear shaft for a K20? Going 14 bolt and need to shorten it.
was also thinking of adding a long travel slip joint while I was at it to increase the contact area extending the life of the shaft. Good idea or too much drag? |
02-14-2015, 04:43 PM | #2 |
Re: Driveshaft shops in Los Angeles area
Inland Empire Driveline Service, best around
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
02-14-2015, 04:47 PM | #3 |
Yes, I've used them many times over the years. Check out their web site. Good tutorial on measuring.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-14-2015, 05:14 PM | #4 |
2WD Jimmy
02-15-2015, 12:38 AM | #5 |
Little closer is General Driveshaft, in Monrovia
and Driveshaft Specialist in Azusa I've only used the Monrovia place but have had family use the Azusa one
'68 C10 SWB '85 K30 Blazer |
02-15-2015, 03:54 AM | #6 |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
02-15-2015, 04:03 AM | #7 |
I have had 2 made by Wenco Ind. in the San Fernando valley. Very pleased, and far less than Cannon Engineering ( North Hollywood) that I used to use in years past.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
02-15-2015, 07:09 AM | #8 |
Wenco
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-15-2015, 11:49 AM | #9 |
I had a mail order shaft from Wenco for my 240z with swapped in turbo T5 and 1310 joint on the rear. I was very impressed with the honesty and quality of work. I had an issue and the guy remembered our call and that it was his mistake. Made it right, made it fast, and my next shaft will most likely be a Wenco as well.
02-15-2015, 12:01 PM | #10 |
Another vote for Wenco. Used them many times over the years.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
02-15-2015, 03:37 PM | #11 |
Who Changed This?
IIRC, Wenco charged me more than Cannon Engineering. I've used both with good results.
